Author Topic: Headlight out???  (Read 2120 times)
Agemo
  • Cleethorpes
  • Insignia
Headlight out???
« on: 11 December 2009, 20:22:33 »
OK gents, I have found I have a headlight out, no problem me thinks, probably just a bulb. Oh no! I have Xenons! Where do I start? Do I need ballast pack? Resistor? Could it be faulty connection? Where do I begin?
Re: Headlight out???
« Reply #1 on: 11 December 2009, 20:43:16 »
Just change the bulb with the one on the other side .. that you know works.... if it works in the failed side you need a new bulb. If it doesn't you need something else  .. but my money's on the bulb .. :)
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 11 December 2009, 20:49:11 »
OK Mate, thanks for that, will give it a go.  :y
« Reply #3 on: 11 December 2009, 20:51:15 »
D2S bulbs are needed and they ain't cheap ... this place is "reasonable"
http://www.autobulbsdirect.co.uk/HID-D2S-Gas-Discharge-Bulb-Lamp-Osram-4100K.html?page=1
You can buy cheaper .. but I like Osram or Philips ... :)
« Last Edit: 11 December 2009, 20:53:39 by entwood »
Agemo
  • Cleethorpes
  • Insignia
« Reply #4 on: 11 December 2009, 21:50:08 »
Been out to look, but it's like Siberia up my drive. Will have a go 2moro. Thanks for the link, I saw a facelift in a scrappy & never thought of needing the bulbs - DOH!
