Author Topic: Info display  (Read 2614 times)
mrcnc53
  • Portsmouth
Info display
« on: 09 December 2009, 20:08:37 »
The colour info display in my Yreg 3.2 went all fuzzy
twice today, like a telly with the ariel out. It came back
after a few minutes and a couple of thumps on the
dashboard. Am I looking at a new display soon?
If so how much and how hard ?
Thanks.. :(
    • 530D M Sport, 330i Coupe
Re: Info display
« Reply #1 on: 09 December 2009, 22:24:30 »
Yep, about £1000 from the dealer, £350 from ebay.de or if you can find one, an LCD panel on it's own for about £200 - guide on here, just some dismantling to do and three solder pads to de-solder.
« Last Edit: 09 December 2009, 22:24:51 by VXL_V6 »
hotel21
  • The Kingdom of Fife
Re: Info display
« Reply #2 on: 09 December 2009, 22:54:43 »
.... or PM either TheBoy or DaveDND.  They may be able to sort you out - for a price, mind, but cheaper than new from a dealer.....   ;)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Info display
« Reply #3 on: 09 December 2009, 23:19:44 »
Not me, my supply of screens has run out   :'(
Radio & Decoding Technician
www.dndservices.co.uk
Re: Info display
« Reply #4 on: 10 December 2009, 10:01:56 »
cheapskate option is to fit a GID (which is not colour) loads more of them about and a damn site cheaper. But loose the nice display.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Info display
« Reply #5 on: 10 December 2009, 16:29:46 »
I have fixed LCD screens on tvs and hand held units from 3inch to 52inch, usually if the screen gose fuzzy there is damp getting inbetween the screen and board can usually be fixed by keeping the unit screen warm for a few hours and resealing the edges of the screen. that is on small screens on large screens have to put screen on a tester and zap the screen until all pixels are working again.
LCD screen is made from a 2 micro piece's of thin glass with a micro mesh inbetween with film of liquid, on small screens there is a board on the back which has the micro connectors on it to connect to the screen these can get damp ( and corrode the copper connectors) if the seal has gone which make the screen go fuzzy, best to be fixed as so as possible or the connectors can be damaged beyond repair,
mrcnc53
  • Portsmouth
Re: Info display
« Reply #6 on: 12 December 2009, 08:26:29 »
Thanks for everybodies replies  :D
Re: Info display
« Reply #7 on: 12 December 2009, 16:19:04 »
Nah, that old wives tale has never worked.
rustym95
Re: Info display
« Reply #8 on: 12 December 2009, 19:41:16 »
well i have done it to loads of LCD screen, I work with them on a daily bases, LCD screen (small screen) are on a board with the lighting, the boards heat in use  and cool down after use which after a time loosens the silicone sealent, damp gets into the screen board, then the problems start coming up, LCD screen do not go that is a myth only the connections ther is not enough volts in a screen to blow them 000.5 volts 3 to 10inc screen, the lights use more volts.
Re: Info display
« Reply #9 on: 13 December 2009, 10:07:47 »
I agree that (physical damage aside) its the internal (or main ribbon) connections that fail.
Drying it, like adjusting the stresses on the screen, will at best only be a temp solution.  As you quite rightly say, its the corrosion thats the killer, and that would be very specialist to repair.
