Author Topic: Estate aerial ???  (Read 2462 times)
I_want_an_Omega
Estate aerial ???
« on: 12 December 2009, 18:00:14 »
Hi,
Regarding a minifacelift estate with combined phone/radio aerial. There will be 2 coax cables running away from the aerial, but do they both run down the passenger side to connectors & then up into the dash, or does one of the cables run down the drivers side kick panel?
I know they both go to the back of the radio cage as two separate coax connections.
Is there also a power connection to the aerial as well or is it totally passive. If so, where does it take the power from?
TIA .......... Rob
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Estate aerial ???
« Reply #1 on: 13 December 2009, 15:01:42 »
there are some power cables with plugs under the rear seats on mine but dont know if it is the same for yours.
I_want_an_Omega
« Reply #2 on: 13 December 2009, 15:37:19 »
They are for the:
1) Heated rear seats
2) Self levelling rear suspension
Thanks anyway Rusty ,,,,,,,
rustym95
« Reply #3 on: 13 December 2009, 20:48:11 »
no not them one's i know them one's they are in the left and right of the door piller on (C) electrics shaped like a T plug, brown and black wire, checked with meter only live when ignition is on had a load of black tape on them each, pulled out of the hole as sore the wires and it just pops out.
    • 530D M Sport, 330i Coupe
« Reply #4 on: 13 December 2009, 20:53:16 »
Aerial loom runs from connector at antenna end (tails on antenna) to drivers kick panel connector then another loom to headunit.
EDIT: Can't spell!
« Last Edit: 13 December 2009, 20:56:13 by VXL_V6 »
I_want_an_Omega
« Reply #5 on: 13 December 2009, 20:56:09 »
The connectors under the passenger side of the rear seat are as I say. One multiplug is for the heated seats, the other for the suspension. Both will be empty unless the car has these features specified.
I can't think of any T shaped connectors in the area.
But, its  meaningless discussion anyway as I'm looking for a black coaxial cable of about 1/4 inch diameter - not a multipin plug.
I think the one for the normal aerial runs down the drivers side of the car.
I_want_an_Omega
« Reply #6 on: 13 December 2009, 20:58:20 »
EDIT: Can't spell!
Yep, as suspected (& thanks) - but its the phone aerial connection that I'm after not the radio aerial one. There will be 2 black coaxs coming off the aerial for cars with the built in phone or the phone wiring kit option.
« Reply #7 on: 13 December 2009, 21:00:04 »
Yes two Coax's, You then need an optional cable to get from the kick panel to the phone kit or CCRT700.
If it's a Nav version you'll have three coax's as the GPS element is in the foot - only mention as externally the boots look the same.
« Last Edit: 13 December 2009, 21:03:29 by VXL_V6 »
I_want_an_Omega
« Reply #8 on: 13 December 2009, 21:03:37 »
Both down the drivers side? I suspect that the phone one goes down the passenger side .......
« Reply #9 on: 13 December 2009, 21:07:23 »
Can only speak for facelift saloon which is definately down the drivers side to the kick panel.
I_want_an_Omega
« Reply #10 on: 13 December 2009, 21:10:16 »
Thats interesting - I'll find out myself later in the week when I get to help myself to a car thats being broken ... :y
« Reply #11 on: 13 December 2009, 21:12:49 »
Does it have Bose????  ::)
I_want_an_Omega
« Reply #12 on: 13 December 2009, 21:16:01 »
Yes, I know about the "unused" coax ..... grrr
