Author Topic: MID Furbared ?  (Read 3198 times)
MID Furbared ?
« on: 15 December 2009, 16:32:20 »
Took the instrument panel out today,when I put it back the MID doesnt work,checked that the plugs are plugged in properly which they are.Dont think its the fuse as Haynes says its the same fuse as indicators etc which work OK,so Im guessing it didnt like being disconnected and has died ? :-/
Re: MID Furbared ?
« Reply #1 on: 15 December 2009, 16:33:32 »
all bulbs in the mid present and accounted for?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: MID Furbared ?
« Reply #2 on: 15 December 2009, 20:46:26 »
Had them out loads of time aways work afterwards, as Tunnie say's and try a reset (hold both stalk buttons in for a few seconds) with the ing. on.
Re: MID Furbared ?
« Reply #3 on: 15 December 2009, 20:53:11 »
its possible the bulbs have gone - may have not had full compliment working before, and with all the moving, the others (tired by now) have given up
RichardH
  • Ireland
Re: MID Furbared ?
« Reply #4 on: 15 December 2009, 21:13:32 »
I had all mine all pop together once when I had the dash out to replace a blown speedo bulb.
Shine a torch at the MID and see if you can still make out the characters on the display.  If you can, then it is just the bulbs that have gone.
Re: MID Furbared ?
« Reply #5 on: 16 December 2009, 14:29:17 »
will try that when its not so cold - sometime in june probably. :y ;D
Anyone know how many bulbs are inside it ? :-/
Re: MID Furbared ?
« Reply #6 on: 16 December 2009, 14:33:01 »
Re: MID Furbared ?
« Reply #7 on: 16 December 2009, 14:47:21 »
Brilliany,thanks Rob. :y
Re: MID Furbared ?
« Reply #8 on: 17 December 2009, 17:36:14 »
Checked today,bulbs blown,have to get some new ones asap.Thanks for the help everyone. :y
