Author Topic: Help needed  (Read 2460 times)
filesy
Help needed
« on: 14 December 2009, 18:21:21 »
Hi, i have an omega 2.2 cdx 2002, on the dash the light with a car and a spanner keeps coming on and staying on, i had it put on a machine and they said it was the transmission controller, code P7.
Can anybody tell me how i resolve this without spending a fortune.
I f the light comes on whilst driving it seems fine but if it comes on when the ignition is turned on it goes very slowly, as if the handbrakes on. If i turn the ignition off and back on it does go off.
Any help gratefully received, thanks.
Re: Help needed
« Reply #1 on: 14 December 2009, 18:26:25 »
you need to get the codes read in full, worth posting up your location we may have tech2 near you. Otherwise its worth investing in a 'cheapo' tech2 from eBay for around £30
With the 2.2 the cam sensor is a common failure, which causes other random codes to appear which has nothing to do with the true fault
Re: Help needed
« Reply #2 on: 14 December 2009, 18:50:11 »
need the codes read properly, not by the fly-by-night who did it last time.
Where are you?
filesy
Re: Help needed
« Reply #3 on: 14 December 2009, 18:53:48 »
Hi, i am in Warrington, Cheshire.
Re: Help needed
« Reply #4 on: 14 December 2009, 19:08:57 »
Have a word with the service manager at Lookers Ellesmere Port aka Dr O aka Phil R who knows his Vauxhalls back to front and lurks in the shadows here sometimes!  :y  :y  :y
filesy
Re: Help needed
« Reply #5 on: 19 December 2009, 10:57:56 »
Hi, the code for my error is p0700
 EOBD Error stored by Transmission Control (TC) Modul B-06
P0700 MIL request from Transmission Control (TC) Modul B-06
Is the modul similar to a relay and if so where is it located or am i completely wrong, thanks for your help.
Re: Help needed
« Reply #6 on: 19 December 2009, 11:03:36 »
are those ALL the codes?  :-?
Things like crank sensor failing can give autobox false codes
filesy
Re: Help needed
« Reply #7 on: 19 December 2009, 11:09:54 »
Yes, thats the only code i was given, p0700 with the 2 possible problems but both relate to the modul B-06
Re: Help needed
« Reply #8 on: 19 December 2009, 11:19:12 »
and the codes from the gearbox and abs unit? Or were the code readers far to stupid to get that?
filesy
Re: Help needed
« Reply #9 on: 19 December 2009, 13:06:00 »
Sorry Boy, i dont understand your question !!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Help needed
« Reply #10 on: 19 December 2009, 14:41:35 »
I think he is trying to tell you that there should be more than one code when read properly
Readings from the other units will assist in the diagnosis
Radio & Decoding Technician
www.dndservices.co.uk
