Author Topic: heated screen relay  (Read 3842 times)
zippo
  • manchester
heated screen relay
« on: 08 December 2009, 21:57:10 »
My rear screen isn't clearing at all, i can hear the relay clicking and the door mirrors clear/defrost fine .
  Has anyone any ideas where i should look next
  Thanks
 Darren
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: heated screen relay
« Reply #1 on: 09 December 2009, 11:38:25 »
try the connectors to the screen, if you have a meter check the volts are getting to the screen, if no volts check the regulator box, think it is in the left side  in the piller.
zippo
  • manchester
« Reply #2 on: 10 December 2009, 00:25:38 »
try the connectors to the screen, if you have a meter check the volts are getting to the screen, if no volts check the regulator box, think it is in the left side  in the piller.[/quot
would that be the c pillar near the spare wheel  :question :question
rustym95
« Reply #3 on: 10 December 2009, 08:52:46 »
inside the boot above the light cluster, behinde the plastic trim, :y or could be in the fist aid compartment as just seen one in the top yesterday. :y
zippo
  • manchester
« Reply #4 on: 22 December 2009, 03:23:28 »
sussed it  :-[ :-[ :-[ :-[ :-[ Rusty fuse . No idea how it got to be in that condition . I assumed that screen and heated mirrors were powered from the same fuse .Should have found this first
http://www.omegaowners.com/forum/YaBB.pl?num=1161602010. cheers Mark DTM  :y
« Last Edit: 22 December 2009, 03:24:09 by zippo »
