Author Topic: interior mists up  (Read 2047 times)
Jack Milloy
interior mists up
« on: 22 December 2009, 17:47:22 »
interior windows all mist up, demister seems to be working,blower o.k.,no water inside car.
Re: interior mists up
« Reply #1 on: 22 December 2009, 17:48:57 »
Check scuttle drain and, if you have climate control, the pollen filter.,... both shouild be clean and dry.
Check vents in the boot, right hand side in behind the little locker are clear.
Make sure recirculation is selected OFF
« Last Edit: 22 December 2009, 17:50:08 by entwood »
Iain
« Reply #2 on: 22 December 2009, 17:57:37 »
Mine does it sometimes too......when you switch it on press the eco button,then press it off again,resets the compressor
Ensure the right hand boot compartment(where the first aid box is) is not obstructed,there are 2 black vents,the car will steam up if that area is full of stuff
