Author Topic: Blower replacement  (Read 4700 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Blower replacement
« on: 17 December 2009, 20:33:50 »
I have read the Haynes Manual on removing the  Heater Blower  but does anybody have any tips on this job My speed controller appears to have failed
Mike Collins
  • North of Bristol
Re: Blower replacement
« Reply #1 on: 17 December 2009, 21:30:17 »
You should not need to remove the blower motor to change the controller, it should pull out from the housing. I had to make a tool from some 15mm copper pipe to pull it though.
Removing the motor is a pain, most of the passenger side air ducting and wiring trunk is in the way.
« Reply #2 on: 17 December 2009, 21:40:24 »
Removing blower motor is a pain in the rse - top two bolts have to be removed (& refitted) by feel!  You need to drop glovebox out, remove trunking tray, undo fixing bolts disconnect electrics and then waggle the b*gger out! As Hayes says "refitting is the reverse of removal"  ;D
Took me a couple of hours to swap blower motors on the Estate whilst standing on my head under the dash!!
« Last Edit: 17 December 2009, 21:40:51 by dbug »
sexydaz
« Reply #3 on: 18 December 2009, 14:34:12 »
i changed my fan speed controller start to finish in my 30 min dinner break,glove box out-look right under at the back(best bet is when youve got your new one and you know what it looks like)two lugs hold it in-one plug 2 wires to change-pop back in and jobs a good un. :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 20 December 2009, 16:46:57 »
Did you change yours because the blower would not turn off even with the ignition off
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #5 on: 22 December 2009, 10:45:34 »
Is the speed controller a small square unit or is it what they call a hedgehog
sexydaz
« Reply #6 on: 24 December 2009, 13:57:04 »
on ebay someones selling them and they call it the hedgehog its a good pic as well,i changed mine cos it packed in all together and got one for a tenner off marky mark but thats a sore point on here at the mo :-X but was it the boy who said it can fail and stay on, i bodged mine till i got replacement by putting a switched earth direct to motor so sounds like yours is putting a constant earth out :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 24 December 2009, 19:33:00 »
 Blower would not stop.  Now fixed with a Hedgehog from Ebay Horrible job no space and lying on back
