Author Topic: adjusting zeon headlight  (Read 2271 times)
V6braveheart
  • Kent
« on: 26 December 2009, 17:19:38 »
First of all Merry Christmas to all.
Can any body help me out with a problem with my car I have a 2001 3.0 V6 Elite. My dipped beam has set at the lowest level and will not adjust automatically as normal. can they be adjusted manually or do I have to pay out for new adjusters from main stealers.
Cheers for any input
« Last Edit: 26 December 2009, 17:27:34 by bigcraig »
Re: adjusting zeon headlight
« Reply #1 on: 26 December 2009, 17:31:52 »
Any message on info display? Both lights or just one?
hotel21
  • The Kingdom of Fife
« Reply #2 on: 26 December 2009, 17:36:56 »
Just to confirm, proper factory fit HID's or xenon lamps fitted to existing lamps?
Any adjuster wheel to the left of the headlamp operating switch?
V6braveheart
  • Kent
« Reply #3 on: 26 December 2009, 17:44:04 »
Yeah a message on the onboard comp says FLD/VISION, MAIN BEAM
V6braveheart
  • Kent
« Reply #4 on: 26 December 2009, 17:46:03 »
There is no adjuster wheel next to the light switch,Factory fitted and its both lights.
« Last Edit: 26 December 2009, 17:49:13 by bigcraig »
hotel21
« Reply #5 on: 26 December 2009, 17:47:29 »
Usual culprit is the adjuster arm coming adrift on the front nearside suspension arm.  Will link a pic in a minute or so...    :y
edit - pic here....  Sensor is roughly in the centre of the picture.
http://www.omegaowners.com/forum/YaBB.pl?num=1219190177
« Last Edit: 26 December 2009, 17:49:35 by hotel21 »
« Reply #6 on: 26 December 2009, 17:48:08 »
you need a diagnostic check done on your car or keep guessing .....  ;).
It's either a level switch on the front nearside wishbone or rear near side radius arm or a level motor in either of your headlamps
Individual lights are adjusted in the standard way with adjusters on eack light - assuming they aren't broken inside.  ;)
« Last Edit: 26 December 2009, 17:49:28 by Andy_B »
V6braveheart
  • Kent
« Reply #7 on: 26 December 2009, 17:57:28 »
cheers will try out and will let you know  :y
V6braveheart
  • Kent
« Reply #8 on: 26 December 2009, 18:13:33 »
Found the problem, where the HID adjuster arm plugs into the rear of the HID sensor has come out. tried to plug it in but think it might be U/S now. ?
