Author Topic: sat nav  (Read 11000 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
sat nav
« on: 15 December 2009, 22:36:37 »
did elite omegas come with built in sat nav??????
Re: sat nav
« Reply #1 on: 15 December 2009, 22:37:59 »
post 1998 yes, Carin?? In Mini-facelifts
Early Facelift Elites did NOT have Sat Nav, but post 2001 they did 2013/2015 units, with optional colour screen
« Last Edit: 15 December 2009, 22:38:27 by tunnie »
Re: sat nav
« Reply #2 on: 15 December 2009, 22:39:44 »
IIRC only the 3.0ltr had it as standard in the mini-face
Re: sat nav
« Reply #3 on: 15 December 2009, 22:41:16 »
pritty sure all Elites did (including 2.5TD) it was leather that was only standard on 3.0's your thinking of  :y
Re: sat nav
« Reply #4 on: 15 December 2009, 22:43:06 »
My 1999 "T" 2.5 Elite had leather but no sat nav :P ;D
Re: sat nav
« Reply #5 on: 15 December 2009, 22:45:37 »
TB's 1998 2.5 TD had no leather but sat nav :P
Re: sat nav
« Reply #6 on: 15 December 2009, 22:46:00 »
i think you maybe right, but most had them, but 3.0's everything was standard  8-)
Re: sat nav
« Reply #7 on: 15 December 2009, 22:46:43 »
:P
Omega 37
  • Northampton
Re: sat nav
« Reply #8 on: 16 December 2009, 16:26:26 »
Ok thanks next question:
If I could get hold of one could I fit it to my facelift 2.2cdx?????
Re: sat nav
« Reply #9 on: 16 December 2009, 16:29:52 »
For facelift you will ned NCDC 2015 or NCDC 2013, along with the GPS which is a little 'bee sting' ariel for saloons which is mounted on the roof, on estates its a large base of the standard ariel.
GPS will need to be connected to the headunit, along with a MID upgrade to GID or CID. Could be a costly upgrade for the factory fit look, and a system that was designed in late 90's
Far easier and cheaper to get a little Garmin unit  :y
« Last Edit: 16 December 2009, 16:31:37 by tunnie »
Omega 37
  • Northampton
Re: sat nav
« Reply #10 on: 16 December 2009, 16:53:37 »
yeah I have one but get fed up of taking it off & putting it on 20 times a day.
can the omega sat nav be updated with the latest maps???
still want one!!!!!!!!!! ;D
cheers
Re: sat nav
« Reply #11 on: 16 December 2009, 17:21:15 »
cheers
Yup, new maps can be added  :)
Re: sat nav
« Reply #12 on: 16 December 2009, 17:31:11 »
Omega37 - have a look at mine if/when you come over.  I have both types in mine.
All post 1998 3.0/3.2 came with some form of satnav, options on all other cars.
Re: sat nav
« Reply #13 on: 16 December 2009, 17:31:33 »
retro fitted ;)
Phil
Re: sat nav
« Reply #14 on: 16 December 2009, 17:37:21 »
Fakra aftermarket GPS antenna solves the issues in Omegas with the radio aerial in the back window.
Vxl Sat Nav is fairly poor, even with the latest disc.
No postcode search, can't find things like Silverstone circuit/ major airports, house numbers in the required road is very limited, just gives you an intersection (hopeless unless you look at a map to see where each road intersection is, negating the need for the sat nav!!) and re-routing because of Traffic jam is crap
If you are going for a retro fit i wouldn't bother with it, not worth the time effort and money
« Last Edit: 16 December 2009, 17:37:44 by Phil »
