Author Topic: Electrical Gremlins!!  (Read 2305 times)
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
« on: 14 December 2009, 19:11:46 »
My 3.0l est was a 2.5 Auto originally and was changed to a 3.0l manual before I took ownership.  About 3 weeks after I got it the reverse lights kept poppoing a fuse, so I did the naughty and fitted a heavier duty fuse and now I have no reverse lights at all.  The bulbs are fine, but I havent tested the switch yet.
Also, not that I believe it is linked, but I fitted a leather interior and now the drivers front seat seems to pop fuse 14 after the seat has been on for a while.
Can anyone help?
2000 Omega Elite 2.5 V6
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Electrical Gremlins!!
« Reply #1 on: 14 December 2009, 21:39:56 »
you may of burnt out a wire or two behind the fuse box, would also check behind the glove box as main wire come into the fuse box from that side.
« Reply #2 on: 15 December 2009, 15:41:05 »
Well, the reverse light wiring will have been hacked about to convert to manual so I would have a look around the gearbox and see what's happened there. Fingers crossed fitting a bigger fuse hasn't caused any further damage.
Blackie_No1
    • Omega Elite 2.5
« Reply #3 on: 28 December 2009, 14:19:24 »
I had burnt out the switch it seems, replaced it, worked for a while but then started popiing fuses again.  After doing a bit of investigation I have found the following:
No front cigar lighter, this has been replaced with a switch for turing the engine fans on incase of paranoia by the previous owner, I suffer from this Vauxhall Paranoia as well always worried that the fans wont come on them selves!!  LOL
I have recently fitted new leather interior with full electrice seats which where wired in by a professional Auto spark
Fuses 14 and 15 are in the cigar lighter circuit and the seat circuits, fuse 14 keeps popping, after a short time when I switch on the drivers fron heated seat, but none of the other seats
The car was originally an automatic but is now a manual using the proper wiring looms and fuse 9 keeps popping when I put her in reverse, but fuse 15 stays intact
So, HELP!!!  It seems to be related to the front drivers seat as far as I can tell as all were working fine before it went in.  The old cloth heated seat and reverse lights worked fine, so I am wondering if I have a short in the drivers seat?
« Reply #4 on: 28 December 2009, 14:35:12 »
Seem to recall another member ascertained dodgy connection @ driver`s seat during certain driving/direction manoeuvres. Disconnect feed to driver`s heat pad then try it
Blackie_No1
    • Omega Elite 2.5
« Reply #5 on: 28 December 2009, 14:55:23 »
Cheers Rob, will give that ago tomorrow morning before I go into work at 1pm
Blackie_No1
    • Omega Elite 2.5
« Reply #6 on: 30 December 2009, 16:21:01 »
Think I've found the problem, or rather Candyman did!!  It seems to be a short in the Caravan plug!!!
Page created in 0.023 seconds with 20 queries.
