Author Topic: Fog light switches  (Read 2639 times)
Dan Hope
Fog light switches
« on: 31 December 2009, 12:41:38 »
Hi All
Does anyone know if the fog light switches on my car should be illuminated?
I notice that in the dark, i can't actually see the buttons so can't tell whether i'm putting the front or back ones on until they're on and the light shows up in the speedo area.
I know in previous vauxhalls (cavaliers/astras) that most switches seem to be illuminated by small bulbs built into the switch and replacements are easily obtainable.
Many thanks
Dan
Welung666
Re: Fog light switches
« Reply #1 on: 31 December 2009, 12:43:25 »
Yes they should be backlit, mine don't work either so I just remember fronts are to the left ;)
Dan Hope
« Reply #2 on: 31 December 2009, 14:18:01 »
cool, well least i know now, thanks ;-)
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #3 on: 31 December 2009, 14:25:15 »
Mine are lit up at night plus dash light to tell me if lights(fog front & rear) are on
« Last Edit: 31 December 2009, 14:25:54 by Selseybill »
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #4 on: 31 December 2009, 20:03:31 »
Illumination bulb behind switches has probably blown.
You need to remove the switch unit, and remove the small bulb holder, (bayonet fitting) replace bulb and refit to switch unit. refit switch unit, and all should be lit okay.
Have recently done this job myself, and can now see the switches!!  :) (should have taken some piccies i suppose. :-[ )
10 min job at most... :y
« Last Edit: 31 December 2009, 20:04:49 by Dodger »
I always knew I'd inherit an estate, but I never thought this would be it!
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #5 on: 01 January 2010, 08:58:07 »
mine is inside the unit, the switches come off and there is a LED at the back, no light in the switch.
Page created in 0.224 seconds with 20 queries.
