Author Topic: Auto gearbox fault codes  (Read 2483 times)
GrayUK
  • Dunstable
« on: 01 January 2010, 18:56:55 »
During the recent cold spell, I started my Omega (Y reg. CDX estate 2.2 petrol).
The automatic change position indicator light kept flashing around from D to P to 3 etc and then had all the lights on.
After a while the engine management light came on (not the car with the spanner).
My current situation is that i have had the codes read by a friend of mine.
P1700 and P700 which point to the TCU. Sometimes I have a full gearbox but the light favours the 3 position occasionally flashing around. Other times i only have manual selection of 1, 2 and 3.
I do not believe the is a ‘real’ fault but a sensor problem.
Can anyone help, or just point me in the right direction please.
Many thanks in advance.
Re: Auto gearbox fault codes
« Reply #1 on: 01 January 2010, 19:00:35 »
Sounds like your selector switch, passenger side of box needs removing, good clean with switch cleaner (not WD40) replacing and re-adjusting.
GrayUK
  • Dunstable
« Reply #2 on: 01 January 2010, 19:05:32 »
Thanks for the fast reply, can you elaborate more please?
« Last Edit: 01 January 2010, 19:06:18 by GrayUK »
« Reply #3 on: 01 January 2010, 19:07:04 »
GrayUK
  • Dunstable
« Reply #4 on: 01 January 2010, 19:14:46 »
many thanks,i will look into it
« Reply #5 on: 02 January 2010, 10:15:55 »
If you read the gearbox codes (assuming your reader can), I suspect you will see a Range Switch fault (Selector switch, as mentioned)
