Author Topic: ELECTRIC WINDOWS ??  (Read 5651 times)
helen
ELECTRIC WINDOWS ??
« on: 31 December 2009, 10:15:07 »
Hi there, i've been silly and tried to open my front passenger window when it was frozen and the control arm came off, i repair the clip bits and i managed to reconnect the window, now when i close it it come back open about 3 inches and i have to on/off the switch to close it . also when i lock my door with the key and i turn fully  the window comes down a few inches and i have to unlock/lock to close it fully. i have tried to program the window as said in the manual but it still does it, any suggestions welcome. thankyou helen.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: ELECTRIC WINDOWS ??
« Reply #1 on: 01 January 2010, 09:00:04 »
try this may work, disconect the battery for about 10-20min then reconect should rest. if not there is a pressure switch in the window unit may be off set, :y
« Last Edit: 01 January 2010, 09:03:02 by Russell_Hill »
helen
« Reply #2 on: 02 January 2010, 13:04:12 »
Hi rustym95, thanks for the reply, i'll give that a go when i get time and i'll let you know how i get on,sounds better than a four pound hammer ? helen.
peter19730
  • manchester
« Reply #3 on: 02 January 2010, 15:24:14 »
sounds possibly like the pressure sensor but try disconnecting the battery for about 20 mins first to reset the system
rustym95
« Reply #4 on: 05 January 2010, 07:52:41 »
have you sorted it out yet? helen
« Last Edit: 05 January 2010, 07:53:01 by Russell_Hill »
helen
« Reply #5 on: 06 January 2010, 08:44:12 »
Hi rustym95, yes i have thanks, disconnected the battery for 15-20 minutes then reconnected and programed them in and they worked perfectly. thankyou for your help and thanks for the other replies, great forum. helen.
rustym95
« Reply #6 on: 06 January 2010, 08:53:22 »
it's ok gald to help :y ;D
« Reply #7 on: 06 January 2010, 10:53:31 »
There is no pressure sesnor on the window setup.....but a power off will reset the motor control module
rustym95
« Reply #8 on: 06 January 2010, 12:06:44 »
if not why, if I push the button the window gose up, it stops if i hold the window and gose down 2 - 3 inches,.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 06 January 2010, 12:21:26 »
Most windows have a current sensing circuit as part of the electronic control box - if the window gets stuck, the current to the motor goes up, and this is then sensed by the circuits and the windows lowered a little to allow whatever was trapped to become free.
Its not a physical sensor or switch though.
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #10 on: 06 January 2010, 12:28:09 »
Correct  :y
unlucky mark mv6
  • tipton,west mids
« Reply #11 on: 06 January 2010, 13:35:38 »
Very clever bloke you are dave,im jealous. ;D :y
