Author Topic: ABS / TC Lights coming on - no Speedo  (Read 3300 times)
Lordmpl
  • Norwich, Norfolk, UK
  • 2.5 V6 Auto CDX - Big Bertha
« on: 05 January 2010, 17:57:10 »
HI,
My friend has a 2.6 elite, and drives fine with no lights, then every now and again the ABS & TC light comes on the speedo stops working...
Any one have any ideas??
Thanks, Mark.
I Love my Omega, wanted it for so long, now it's in my grasp, it's not getting away!!
Re: ABS / TC Lights coming on - no Speedo
« Reply #1 on: 05 January 2010, 18:01:08 »
ABS ecu. Refurb own unit for about £110 by specialists or get one from same spec
Lordmpl
« Reply #2 on: 05 January 2010, 18:04:20 »
would that cause the speedo fault then??
Where abouts is it situated??
Thanks, Mark.
« Reply #3 on: 05 January 2010, 18:26:55 »
Yes it would cause speedo fault, it's behind the battery IIRC, long time since i replaced mine  :y
« Reply #4 on: 05 January 2010, 19:28:00 »
Definite symptoms of breaked abs ecu.  Its behind battery and below power steering fluid resevoir - look down and you will see a large multipin electric plug in it.  The ecu is bolted to the abs block - lots of brake pipes attached.
Symptoms can and will include abs/tc lights on, no speedo, no TC, no cruise control, and in some cases lack of power steering.
Awkward but doable DIY job - fiddly due to lack of space.
HTH
goonv6
« Reply #5 on: 06 January 2010, 20:47:20 »
Yup, its gone. Mine has too and I shall be replacing it shortly, there is a how to here:
http://www.omegaowners.com/forum/YaBB.pl?num=1152729807
I'm thinking of doing one to compliement this but the guide is thorough.
Welung666
« Reply #6 on: 06 January 2010, 21:02:01 »
Best folks to recon the ABS/TC ECU is a company called BBS Reman, google them :y
