Pages: [1] 2 3  All   Go Down
Author Topic: Car with Spanner Light  (Read 6670 times)
davidwb
  • Warrington, Cheshire
« on: 11 January 2010, 13:17:51 »
Hi
Can anyone help, I am driving a 2002 2.2 CDX Auto and the car with spanner light comes on when driving. It goes off once the car has been restarted and will not come on again straight away but one or two days later. A new TPS Sensor has just been fitted because of the code that was displayed, but now the garage say there are no codes to display when checking but the light still comes on. The car is running ok, could this just be one of them things, is this a common problem or should I get it back in the garage.
Any info would be very helpful.
Thanks
Re: Car with Spanner Light
« Reply #1 on: 11 January 2010, 13:19:12 »
Where are you based? Sounds like the person who looked before is one not to use again.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 11 January 2010, 13:19:57 »
might be the service light.
Welung666
« Reply #3 on: 11 January 2010, 13:21:54 »
Where are you David?
« Reply #4 on: 11 January 2010, 13:28:25 »
Not on an Omega ;)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #5 on: 11 January 2010, 13:30:14 »
Hi
Thanks
Welcome to OOF David. Keep posting here, and I'm sure your problem will be resolved. :y :y :y
davidwb
« Reply #6 on: 11 January 2010, 13:36:40 »
I am in Warrington and the garage is Black Diamond Ltd.
They said they have reset all codes, they also replaced the ignition coil and 4 new spark plugs.
They said that Vauxhalls have always displayed that car with spanner light even when there is nothing wrong, is this correct.
Thanks
« Reply #7 on: 11 January 2010, 13:39:24 »
Thanks
That is utter rubbish!!!
So they are randomly changing parts, at your expense, guessing at the fault?  Disgusting.
Come on OOFers, we got anyone with a code reader near Warrington?  This new member obviously requires help, as the garage he is using is poor  >:(
Welung666
« Reply #8 on: 11 January 2010, 13:41:24 »
Thanks
Agree with TB, complete bo11ox. The spanner light is the EML (engine management light) and will only light when there is a fault. I'd try and find someone else, maybe a member here with a code reader, to check the codes for you.
Welung666
« Reply #9 on: 11 January 2010, 13:42:58 »
Thanks
I'm a bit far unfortunately, but would gladly otherwise.
rustym95
« Reply #10 on: 11 January 2010, 13:42:59 »
could they have done the faulty reset that have herd about to make you keep coming back??
« Reply #11 on: 11 January 2010, 13:44:59 »
Thanks
Me too :(
davidwb
« Reply #12 on: 11 January 2010, 13:48:14 »
The garage seem to be getting fed up with me because they don't know what they are doing I think. Will the codes need to be read when the light is on as it is very random when it comes on.
I have been driving very slow in the snow this last week and the light as not come on as much, went to work on the motorway today and the light came on all the way.
Thanks
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #13 on: 11 January 2010, 13:53:30 »
Could the reason for a lack of codes be because the garage are using a basic code reader and not a Tech2 ?
Radio & Decoding Technician
www.dndservices.co.uk
Welung666
« Reply #14 on: 11 January 2010, 13:54:09 »
It should store the codes so they can be read even if the light has gone off.
Have you noticed an increase in fuel consumption?
Pages: [1] 2 3  All   Go Up
