Pages: 1 [2] 3  All   Go Down
Author Topic: Car with Spanner Light  (Read 6649 times)
davidwb
  • Warrington, Cheshire
Re: Car with Spanner Light
« Reply #15 on: 11 January 2010, 13:54:33 »
can anyone recommend a garage in Warrington or Chester which have the diagnotic equipment and skills required or should a just buy a fault code reader for around £30.
Welung666
« Reply #16 on: 11 January 2010, 13:55:12 »
Could the reason for a lack of codes be because the garage are using a basic code reader and not a Tech2 ?
Could well be, a lot of the cheapo's can't pick up the full range like the gearbox ECU for example.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #17 on: 11 January 2010, 13:55:20 »
davidwb - update your profile with your location, it may prompt someone nearby to assist if they can instantly see where you are located
Radio & Decoding Technician
www.dndservices.co.uk
Welung666
« Reply #18 on: 11 January 2010, 13:56:18 »
Elite Pete isn't far away is he?
davidwb
« Reply #19 on: 11 January 2010, 13:56:53 »
I am getting about 25 miles to the gallon and I drive 60 miles each day.
Thanks
Welung666
« Reply #20 on: 11 January 2010, 13:58:32 »
Thanks
Motorway? A Roads? Round town?
davidwb
« Reply #21 on: 11 January 2010, 14:10:24 »
I get about 25 miles to the gallon and drive 60 miles each day.
Thanks
davidwb
« Reply #22 on: 11 January 2010, 14:11:34 »
motoway for 40 miles A roads for 20 miles.
Welung666
« Reply #23 on: 11 January 2010, 14:13:43 »
Should be in the low 30's in that case. Possible Fuel trim/MAF/Outside temp. sensor code will be present.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #24 on: 11 January 2010, 14:20:09 »
did the garage put all the wire's back on that they may of taken off....
davidwb
« Reply #25 on: 11 January 2010, 14:43:36 »
is there anyone in Warrington or Chester who can read the fault codes with the correct equipment for me because if it points back to the TPS which was replaced I can inform the garage because they fitted the new part.
Thanks
« Reply #26 on: 11 January 2010, 15:24:05 »
Thanks
There is a member not far from Chester with reasonable code reader who may be able to help....
« Reply #27 on: 11 January 2010, 16:13:44 »
Thanks
ask for Phil Roberts at Lookers Ellesmere Port and tell him we (or Andy B  ;)) have sent you!  ;)  ;)  ;)   :y He'll know!
« Last Edit: 11 January 2010, 16:14:22 by Andy_B »
davethediver
  • Blackburn, Lancs.
« Reply #28 on: 11 January 2010, 23:30:03 »
Thanks
Did the breathers get cleaned out and the throttle body when they changed he TPS?
P.A. Caron de Beaumarchais
oceansoul
  • Sunbury on Thames - Surrey
« Reply #29 on: 12 January 2010, 15:50:26 »
Mine comes on occasionally. Stays on 3 or 4 miles then goes off again. No difference in the car at all in the way it drives. Only happens rarely too.
Pages: 1 [2] 3  All   Go Up
