Author Topic: cdc 7 safe on console display  (Read 4103 times)
ian bond 007
« on: 13 January 2010, 20:33:12 »
Since being in a real good auto electrical repair garage with my omega...and due to disconnection of the battery for a while to undertake the work,it said safe on the (philips model ccr 2006 console.) when i got in the car to start it with ignition on..so i input the code i use and pressing the AS button too and waiting for the bleep and it then said 10 safe then wait a bit then input the code and then 9 safe wait a bit longer and so on...it now says... cdc 7 safe...Now the car alarm goes off when you try to start the car and wont switch off till i jump start the car with another brand new battery and jump leads(one new for the car and one new to jump from)now the cars started and running fine with cdc 7 safe on the console, no radio, no cassette, no cd player either...until switch off then its all over again...key in the door central lock working fine,then loud alarm howlin... flat brand new battery too...click click click... cdc safe 7 on the console same as usual...i cant do anything with it and the date is always reset to 1997 jan 1.whats its problem?? help needed on this please omega owners and fans....thank you from ian.
Re: cdc 7 safe on console display
« Reply #1 on: 13 January 2010, 20:35:31 »
....so i input the code i use and pressing the AS button too and waiting for the bleep and it then said 10 safe then wait a bit then input the code and then 9 safe wait a bit longer and so on...it now says... cdc 7 safe... .....
Sounds like you're putting the wrong code in ........  :-/
ian bond 007
« Reply #2 on: 13 January 2010, 21:08:06 »
i use the same code i used since it was bought in 2002... problems now though...what could be causing this problem it wont let me input a code at all...it says cdc 7 safe since 2009 january february last year.nothing works only on off button.if i switch it off all the console lights go out switch it on and they light up but i cant input any code i have....
« Reply #3 on: 13 January 2010, 21:31:23 »
Guessing the radio works, just not the cd?
Known issue with that model, sadly needs to be sent off for repair.  A regular member in this section runs a repair business that can do it - Dave DND
ian bond 007
« Reply #4 on: 13 January 2010, 21:46:49 »
nothing works cant input any code it only lights up and the console says cdc 7 safe.....and the date is jan 1 1997 always whats the problem do i need a new unit just because the battery was disconnected??
« Reply #5 on: 13 January 2010, 21:48:19 »
OK, that probably is a question for Dave DND, a audio repair specialist.
ian bond 007
« Reply #6 on: 13 January 2010, 22:04:04 »
thanks loads thats a good start cheers...is dave dnd on this forum then?? i will try to find him thanks
« Reply #7 on: 13 January 2010, 23:33:04 »
He is but we think he may be ill at the moment...
See here :y :y
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #8 on: 14 January 2010, 01:43:59 »
what area are you in? I have a radio reseter, not used it yet as not need'd to.
« Last Edit: 14 January 2010, 01:53:57 by Russell_Hill »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 14 January 2010, 10:50:55 »
Head unit and radio will each require a different code, and I can guarantee that from your description, that you have inputted 3 incorrect codes into the CDC2, hence now giving the error message of 7-Safe.
That now means that you will need to leave the radio and ignition switched on for up to 2 hours to reset before you enter another code number -
DO NOT ENTER THE SAME CODE YOU HAVE BEEN UNSING - IT IS INCORRECT
I can help with the CDC2 code here
http://www.dndservices.co.uk/Vauxhall-CDC2-omega-code.html
Radio & Decoding Technician
« Reply #10 on: 14 January 2010, 14:23:48 »
The OP states that`s it`s a CCR2006. One code only.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 14 January 2010, 14:32:53 »
OK - there is obviously a conflict here.
In order to assist further, we need to be certain what the model number is, what the display says, and exactly what is being done.
If code for a 2006 is being asked for, CDC and a number is NOT within its vocabulary.
CDC SAFE and a number only applies to an external changer, and again is NOT within the vocabulary of a CCR2006
CDC-SAFE without a number indicates a software failure of the CCR2006 head unit
SAFE and a number less than 10 means an incorrect code has been entered into a head unit
More info needed
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 14 January 2010, 14:35:43 »
Actually, might be advisable to get the unit sent over here and lest see what we can find for you - I have a suspicion that the head unit is codelocked and the changer may have failed
http://www.dndservices.co.uk/product.php?productid=528&cat=0&page=1
Page created in 0.022 seconds with 20 queries.
