Author Topic: Minor niggle on CCR2006  (Read 4852 times)
MickAP
  • South Derbyshire
« on: 14 January 2010, 15:26:58 »
Bought a secondhand unit and everything works on it except.....random CD play doesn't work. Also whenever I turn the ignition back on the radio set station does not always come back up, it says 87. etc.
Ok little anoyances but is there a fix, reset I can do or even repair, if it's worth it ::)
Mick ;)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Minor niggle on CCR2006
« Reply #1 on: 14 January 2010, 15:28:49 »
do you mean its not holding it memory aswell?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 14 January 2010, 15:30:13 »
Mick ;)
Sounds like an EEprom failure to me
Try removing the set for an hour, then refitting again.
Radio & Decoding Technician
www.dndservices.co.uk
MickAP
  • South Derbyshire
« Reply #3 on: 14 January 2010, 15:51:49 »
Mick ;)
Will give it a try :y
Mick
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 14 January 2010, 16:02:15 »
Random CD fault can also be poor laser condition, or marked surfaces on the discs - remembering of course that you should not use CDR/RW discs on that machine.
MickAP
  • South Derbyshire
« Reply #5 on: 14 January 2010, 17:06:21 »
Can't say whether they have been used before I aquired it, but know not to use them. :y Random indictor does light up on display when used. Could this be a button/contact failure?
Mick
« Last Edit: 14 January 2010, 17:07:06 by MickAP »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 14 January 2010, 17:43:47 »
Mick
unlikely, if the display changes to indicate button has been pressed, then assume that the circuit is working and the fault lies either with laser (which would show up other faults like inability to read all discs) or more likely, the internal eeprom has failed (24LC02 ?) and is unable to retain any status memory  - also gives the faults of forgetting presets, defaulting to a different waveband, random code entry etc etc.
MickAP
  • South Derbyshire
« Reply #7 on: 14 January 2010, 17:47:56 »
Mick
Sorry should have said random indicator does not light up when selected typo error ;D
Mick
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #8 on: 14 January 2010, 17:51:39 »
Mick
Mick
Inthat case would suspect a bad connection between front fascia pcb and main pcb of the cassette part.
Small edge connectors visable when fascia taken off, usually break or bend pins when fascia incorrectly put back on. Suspect the one on the right hand side
MickAP
  • South Derbyshire
« Reply #9 on: 14 January 2010, 18:10:56 »
Thanks Dave will take a look :y
Mick
Page created in 0.023 seconds with 21 queries.
