Author Topic: Ncdc2015 Wont eject  (Read 3374 times)
bigmac
  • Devon
Ncdc2015 Wont eject
« on: 13 January 2010, 17:55:51 »
Hi guys i have a problem thats just popped up today when i tried to eject my cd cartridge nothing happens :( i get flap open but cartridge wont eject and it doesnt look like its even trying
No errors at all and all CD's swap and play fine
Any idea's
Re: Ncdc2015 Wont eject
« Reply #1 on: 13 January 2010, 18:21:57 »
Does stuff still play now, or is it jammed?
If jammed, stripdown.  If still working, stripdown to check plastic that operates the microswitch to tell unit to eject.  I think flap open is purely mechanical from meory
bigmac
  • Devon
« Reply #2 on: 13 January 2010, 18:26:47 »
Hi jaime CD's play fine and i can change disc no problem by pressing 1-4 but i press eject and the flap pops down but cartridge doesn't budge at all,ive seen ones that are stuck and they at least try to eject but mine seems life less no sound or movement
« Reply #3 on: 13 January 2010, 18:30:34 »
reckon the switch is next port of call.  remove facia (obviously radio needs to come out of car), and check that
bigmac
  • Devon
« Reply #4 on: 13 January 2010, 18:36:28 »
Will do  :y do they come out of allign or will the switch be knackered ? if it is the switch is it an easy fix ?
« Reply #5 on: 13 January 2010, 18:41:19 »
suspect is the plastic button itself.  but you'll have to strip to find out
bigmac
  • Devon
« Reply #6 on: 13 January 2010, 18:43:16 »
Is it possible to pull stereo out a bit then take front off or does it all have to come out
« Reply #7 on: 13 January 2010, 18:50:09 »
easier to pull it all out - some of those torx screws go through facia, and the clips can be fiddly
bigmac
  • Devon
« Reply #8 on: 13 January 2010, 18:57:40 »
Will give it ago over weekend then  :( will report back what i find
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 14 January 2010, 10:36:49 »
Don`t remove the fascia whilst the unit is still fitted, it will cause some nasty problems.
There are two common problems with that mech jamming, one is purey mechanical with the cartridge clips going the wrong side of the mechanism, and often cured by carefully stripping it down and reassembly, the other is the plastic lug on the flap that breaks off and does not actuate the small switch correctly meaning that the unit will not go into eject mode at all
Spares are very hard to find  :(
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #10 on: 14 January 2010, 18:32:27 »
when it jams, it stops disks loading in my (limited) experience, so likely the switch (plastic bits)?
bigmac
  • Devon
« Reply #11 on: 14 January 2010, 18:52:41 »
Anyone got any spares  :'(
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 14 January 2010, 23:08:43 »
Yep, depending on what state the switch is in when it breaks, it can prevent it from loading or ejecting.
