Author Topic: subwoofer instalation  (Read 3681 times)
dreads
  • london
« on: 11 January 2010, 01:03:45 »
could any one tell me were the nearest switched live is in or near the boot, an what colour the wire is.
sparkyw666.
  • aberdeen uk
  • aka mark w
Re: subwoofer instalation
« Reply #1 on: 11 January 2010, 01:47:39 »
if your going to put in a sub and a amp i would take the power straight from the battery tbh :y
v6 cam locking kit  member:y
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 11 January 2010, 02:37:28 »
I can only hope assume you are looking for a 'remote' wire to power your amp when the ignition is live.
Seeing as you have to run a LIVE cable from the battery along the length of the vehicle, I'd suggest you run the remote properly from the back of the head unit and not cut corners.
« Reply #3 on: 11 January 2010, 09:14:58 »
I'm with Broomies Mate - surely you are not considering powering amp/sub from a nearby 12v :o.  It needs to be run direct to battery, with an inline fuse as near to battery as possible!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 11 January 2010, 10:51:48 »
Correct
DO NOT USE A SWITCHED LIVE FOR AN AMP   >:(
The amp remote must only be powered from the remote feed from the head unit  ;)
Radio & Decoding Technician
www.dndservices.co.uk
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #5 on: 11 January 2010, 11:30:30 »
might be a 20w amp.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 11 January 2010, 11:50:37 »
might be a 20w amp.
Doesn`t matter on the size of the amp - the remote turn on signal is designed to switch at a slightly different time to the head unit and prevent any unwanted turn on audio "thump" that can destroy speakers instantly.
rustym95
« Reply #7 on: 11 January 2010, 13:10:24 »
was joking. ;D
  • Auckland
    • Mazda MPV
« Reply #8 on: 12 January 2010, 17:25:02 »
Doesn't the antennae feed from the back of the head unit go to the aerial amplifier in the rear parcel shelf?
« Last Edit: 12 January 2010, 17:25:52 by andyh »
rustym95
« Reply #9 on: 12 January 2010, 19:17:55 »
all wire's are 5-10 wat in most of the back with some 3wat wires as well, so would start to melt.
KillerWatt
« Reply #10 on: 12 January 2010, 23:31:03 »
might be a 20w amp.
Power output is immaterial, it's what the PSU inside the amp wants that matters (and they normally want a fair whack).
As others have already stated, nice bit of 4 guage with inline fuse straight off the battery (inline fuse as close to battery as possible), and the amp is "switched on" by the remote lead from the head unit.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #11 on: 14 January 2010, 10:27:16 »
might be a 20w amp.
The man knoweth of what he preaches   :y
KillerWatt
« Reply #12 on: 16 January 2010, 11:42:27 »
might be a 20w amp.
I'd hope so Dave, I've spent £1000's over the years on exams (some pointless) that have been introduced by the government to prove I still know what I learnt 30 years ago
@ the OP
I did forgot to add that the ground lead should also be in the same guage as the main power line from the battery (although common sense should dictate that anyway), and also keep the wires as short as poss to minimise the volts drop.
dreads
  • london
« Reply #13 on: 17 January 2010, 02:48:58 »
thanks for the information ill try and install it professional!
