Author Topic: Couple of queries  (Read 2394 times)
SMD
  • London
    • :( nowt
Couple of queries
« on: 17 January 2010, 17:45:58 »
Tried to replace the OE stereo to get the steering wheel functions back but the unit is a real struggle to fit. It wont go in more than halfway. Any tricks/tips to get it in other than brute force?
Secondly the temp sensor was indicating 25 degrees C during the 'big freeze'. How do I replace this? Car is a R reg (mini facelift I think)
Ta
goonv6
Re: Couple of queries
« Reply #1 on: 17 January 2010, 18:07:31 »
Yes, are you trying to put the unit in with the cage or put the cage in first? I put the cage in first, reached in and carefully moved all the block connectors out of the way. It is a tight fit but it does go. Check also that you haven't distorted the sides of the cage.
« Last Edit: 17 January 2010, 18:08:05 by goonv6 »
SMD
  • London
    • :( nowt
« Reply #2 on: 17 January 2010, 19:25:17 »
tried it both ways. the problem is the back of the case is closed and i cant get my hand in to move the connectors out of the way.
i probably didnt make it clear that i am trying to put the OE stereo back in.
« Last Edit: 17 January 2010, 19:30:31 by SMD »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #3 on: 17 January 2010, 20:43:33 »
have tyed moved the wires to bottom before putting in the unit.
SMD
  • London
    • :( nowt
« Reply #4 on: 17 January 2010, 21:52:54 »
yes, tried that. the OE cage is a bit longer than the stereo so i also tried it with my other cage which fits out of position but not in situ  :(
« Last Edit: 17 January 2010, 21:53:21 by SMD »
