Author Topic: Left Side Speakers  (Read 3636 times)
stevi1983
  • South West
Left Side Speakers
« on: 06 December 2009, 01:22:13 »
Hi
Got the radio working in the car, but for some reason only the drivers door speaker and the right passengers door speaker works, the two on the left hand side dont seem to work
anyone any ideas
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Left Side Speakers
« Reply #1 on: 06 December 2009, 02:43:42 »
it might be the speakers but could allso be the flex bettween A post and door, i would say the door wire. :y should un screw, give a good clean and check the wires. :y
p j morgan
  • nottingham
« Reply #2 on: 06 December 2009, 02:47:58 »
think you should pull the radio out and try and reset the plug that goes in the back of the radio ?more than likely the plug as not been pushed right in!good luck and hope you sort it :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 06 December 2009, 08:48:20 »
Always try the balance control first
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #4 on: 06 December 2009, 12:46:15 »
Absolutely.....check the balance control
stevi1983
  • South West
« Reply #5 on: 21 January 2010, 20:58:47 »
Ahh, got it fixed, it was the balance controll, should have read the manual first, did'nt relise you had to pull out the voluame controll to adjust the ballance. What a TIT, had the door panels off etc. Leason learned 2 month later...............
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 21 January 2010, 21:06:24 »
 :-X   ;D
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 22 January 2010, 08:33:04 »
This is probably the 100 problem with the same solution ;D
Dave it is easy to be an expert when you have problems like this :D
Just kidding of course.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #8 on: 22 January 2010, 09:43:07 »
Shhh !!      ::) :P
