Author Topic: Strange beeping from OSR flasher..!!  (Read 6740 times)
cruisetopoland
  • UK
« on: 04 January 2010, 12:50:13 »
My Omega has recently started beeping a quiet acknowledgment on locking/unlocking via remote when hazards flash-from the boot area, and now this beeps quietly in time with the right indicator/flasher or hazards-but not the left!!  Huh??
Car has a towbar and aftermarket rear parking sensors, but not towing at present and sensors switched off (sounder on rear shelf-so not this).  It's not the power sounder, so I'm guessing its a beeper repeater for the towbar indicators, located near the boot lock somewhere as this is where the sound is coming from.
Any ideas??
Guessing that it is a towbar wiring issue?
Comments appreciated...
Re: Strange beeping from OSR flasher..!!
« Reply #1 on: 04 January 2010, 12:53:42 »
Any ideas??
Just follow the wires back from the indicators, & when you've found the box rip it out! Replace the 3 pin flasher unit in the front fuse box (under steering column) with a 4 pin, put a lamp in the dash for the trailer tell-tale and you're sorted! Lazy towbar fitter couldn't be 4r$ed removing the dash!  :y
cruisetopoland
  • UK
« Reply #2 on: 04 January 2010, 13:08:48 »
Any ideas??
Cheers-won't be towing so will just take off plastic cowl, find beeper, remove it and join wires for now.
Where do I get a 4 pin and bulb from if needed?
Is towbar checked on MOT?
Thanks  :y
Iain
« Reply #3 on: 04 January 2010, 13:09:19 »
Its not the power sounder battery warning is it??
cruisetopoland
  • UK
« Reply #4 on: 04 January 2010, 13:10:26 »
Power sounder replaced in 2008 by VX and is located under bonnet, so guessing it's not this!
Iain
« Reply #5 on: 04 January 2010, 13:12:16 »
Was only a suggestion!!
cruisetopoland
  • UK
« Reply #6 on: 04 January 2010, 13:19:20 »
Cheers-appreciated  :y :y
« Reply #7 on: 04 January 2010, 13:21:33 »
Thanks  :y
Halfords do flasher relays & I'm sure they do the little lamps - there's two wattages (is that a word?) available if not Halfords then the dealers sell them.
Towbars have just recently been included in your MOT but only from a meachanical/integrity point of view - it does NOT check the electrics.  :y
Iain
« Reply #8 on: 04 January 2010, 13:23:57 »
cruisetopoland
  • UK
« Reply #9 on: 04 January 2010, 13:24:14 »
Thanks  :y
Very helpful and informative-many thanks indeed Andy  :y :y
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #10 on: 04 January 2010, 17:57:57 »
Any ideas??
I guess I could maybe use the same 4pin idea to feed a louder buzzer for indicators Andy, what say you :-? :-? :-?
PS to Mods, Sorry if slightly off topic
« Reply #11 on: 04 January 2010, 21:02:21 »
...... I guess I could maybe use the same 4pin idea to feed a louder buzzer for indicators Andy, what say you :-? :-? :-?
The 4 pin flasher wil give a tell tale on the dash, so you won't need a buzzer!  :y  :y  :y
Shackeng
  • Ramsbury
« Reply #12 on: 05 January 2010, 13:15:38 »
Sorry to appear dense, but where would you put the flasher? The existing ones, are not obvious beacause of wheel position and seat well back. :-? :-? :-?
« Reply #13 on: 05 January 2010, 13:27:48 »
You swap one for the other. It's in the relay/fuse box under the steering column, opperater the hazzards and you can feel which one is clicking ....... too much snow outside to go & look at mine!!  ;D ;D
Shackeng
  • Ramsbury
« Reply #14 on: 05 January 2010, 19:09:05 »
Sorry Andy, I didn't make myself clear. I meant where in the dash lighting can you fit an extra light? (I've never had mine off so apologies if it is obvious) :-?
