Author Topic: rear window conversion  (Read 4809 times)
stuthespread
  • stevenage,herts
  • no spring chicken
« on: 28 January 2010, 16:12:14 »
i've just converted my manual rear windows to electric,problem is i don't seem to have any power going to them(light in the switch not illuminating)i replaced the loom to accomodate the motors etc,reset the windows but nothing's happening.the front windows are working fine and the rear switch lights on the switches in the centre console are illuminated as they should be,i've also checked the fuse.should anything else have been fitted apart from the motors as there is a spare connector on the loom that doesn't seem to go anywhere.
cruisetopoland
  • UK
Re: rear window conversion
« Reply #1 on: 28 January 2010, 16:15:28 »
joshwyatt is the man for this as he converts ex-police to standard spec-I know he was with welung666 doing this last week :y
Try pm-ing either :y
« Last Edit: 28 January 2010, 16:18:26 by geoffharvey »
Welung666
« Reply #2 on: 28 January 2010, 16:25:38 »
We had to put it off due to Josh's RTC. Check the wire colours under the rear door switches and check for the same colours in the drivers footwell.
cruisetopoland
  • UK
« Reply #3 on: 28 January 2010, 16:31:15 »
Oh yes-the Rangie  :'(
Glad it wasn't serious..
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #4 on: 29 January 2010, 11:31:02 »
checked the wiring on the loom that comes from the car to the door and it would appear that all the wires are missing from the plug.can this just be replaced with correct loom or is it a bit more complicated than that?
Welung666
« Reply #5 on: 29 January 2010, 12:19:05 »
Looks like you'll need to change the sections both sides from the kick plates back to the B post. What year is your car?
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #6 on: 29 January 2010, 13:26:56 »
1999 (s)saloon
Welung666
« Reply #7 on: 29 January 2010, 16:14:22 »
Surprised it's not already fitted!
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #8 on: 29 January 2010, 19:07:58 »
I am suprised as well. mine had them fitted and all i had to do was fit the door loom into the door and Bongo it all worked.
Jaguar XJ6
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #9 on: 29 January 2010, 19:32:17 »
unfortunately not on my car,could do without all the aggro to be honest.
