Author Topic: Q:unknown connector next to coolant tank  (Read 2277 times)
olzz
« on: 17 January 2010, 17:29:38 »
Hey all!
I need help for finding the answer for the loose connector under the bonnet. There is 2 pin connector hanging, 2days i have been searching the answer plug. It comes through the cabin fire-wall together with the coolant tank level sensor wire. Please see the pictures below:
http://img51.imageshack.us/i/imgp7563.jpg/
http://img189.imageshack.us/i/imgp7566v.jpg/
PS! The car is with left steering configuration :)
Could anybody check his/her Omega 2,2 bensin, where this connector is connected!
Thank you in advance!!
I_want_an_Omega
Re: Q:unknown connector next to coolant tank
« Reply #1 on: 17 January 2010, 18:03:41 »
Aux coolant pump?
Put a meter on the contacts, if you get 12v when the ignition is on then thats what it will most likely be
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 18 January 2010, 01:04:01 »
looks like it has never been used, mine not used as well tyed up with cap on it and put in with the alarm horn.
olzz
« Reply #3 on: 18 January 2010, 21:28:52 »
Voltage measurement done. No power coming, when ignition is on...
Most probably it is Omega standard wiring kit, and not used with  current engine
secarianu
  • Constanza, Romania
« Reply #4 on: 29 January 2010, 22:54:49 »
Mate, I know from other forums in my country (clubopel.com) that it is for testing the HID xenon system.
« Last Edit: 29 January 2010, 22:55:11 by secarianu »
"SPLENDID" OMEGA Y22DTH
***THE QUEEN***
