Author Topic: Time and Date setting on info display -HOW???  (Read 2820 times)
chrisgc
  • Swindon, Wiltshire
« on: 30 January 2010, 13:53:18 »
Hi
On my 1998 Elite I have the clock on info display with the two little buttons to set the date and time above the display.
Thing is when I press the both button to set the time (as always showing 0.00) nothing happens.
Also not sure if related but in the info display on car start up it shows Mem and it searches all the time untill I press a station button on the radio.
Is there some kind of memory feature which is not working or a battery etc.
Any help would be greatly appreciated.
Chris
Re: Time and Date setting on info display -HOW???
« Reply #1 on: 30 January 2010, 14:00:02 »
Hi
Chris
Tune the radio to a proper RDS station (BBC stations are pretty good) and the Date/Time should set automatically within about 5 minutes :y :y
« Reply #2 on: 30 January 2010, 14:11:51 »
Has the radio been changed?  If so, need to set manually. Press and hold left button (I think!) for 3s, then the other button changes flashing value, original button moves to next value.
If orig radio, tune to Radio2 for 15 mins ;D
« Reply #3 on: 30 January 2010, 14:13:40 »
Must be original... He said the display shows Mem and starts searching until he presses a radio station preset button.
Incidentally... Mine does that too if tuned to a station with a weak signal :y :y
  • Auckland
    • Mazda MPV
« Reply #4 on: 30 January 2010, 15:14:59 »
Does the radio actually play anything once it has done a search? My suspicion is that the fragile aerial lead on the back of the headunit has broken / fallen out.
oceansoul
  • Sunbury on Thames - Surrey
« Reply #5 on: 30 January 2010, 15:38:55 »
Does Radio 2 work for rds clock? I set the radio in a work van to auto do the time via rds as it always wrong. Didnt get anything from Radio 2. Set it to Radio 1 and it instantly updated the time :y
« Reply #6 on: 30 January 2010, 15:52:04 »
Must do because I've never listened to Radio 1 in the car and mine sets on RDS :y :y
I believe all BBC Radio stations do RDS Time
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 30 January 2010, 18:18:25 »
All BBC RDS stations transmit the time, but the frequency can vary, some up to 15 mins.
Classic FM is the fastest to update, as continually carries much of the extra RDS and TMC information used by the other channels, with Radio 4 being next.
Radio & Decoding Technician
www.dndservices.co.uk
chrisgc
« Reply #8 on: 30 January 2010, 20:27:58 »
Have tried the button settings above the clock display - no joy.
No joy with the rds setting either - had radio one on for an hour and didnt set.
Any more tips please?
Chris
« Reply #9 on: 30 January 2010, 20:44:16 »
