Author Topic: Outside Temperature Sensor Reading  (Read 2427 times)
StevieP
  • Northamptonshire
« on: 01 February 2010, 17:58:59 »
My Car - 2001 2.6 Omega.
Currently not showing the outside temp on the display, It has an F there instead.
I have changed the sensor behind the bumper twice now and the fault is still there.
I take it you just unplug the sensor and plug the new one in ?? And all should work.
Has anyone any Ideas on what else I could try to get this rectified ????
Steve.
Re: Outside Temperature Sensor Reading
« Reply #1 on: 01 February 2010, 21:20:24 »
Just a case of testing the wiring then... Probably a bad connection in the loom. IIRCC there is another plug further back in the loom ;) ;)
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 02 February 2010, 01:41:51 »
would look at the back of the MID, can pop out if plug not put in right. or pushed in at an angel :y
« Reply #3 on: 02 February 2010, 08:15:40 »
Big connector, passenger side, near the bumper bottom.check it for water ingress etc.
This will also affect the climate operation
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #4 on: 02 February 2010, 17:30:16 »
Thats why my climate went silly whilst the outside temp sensor started reading 65 deg..
4candles
« Reply #5 on: 07 February 2010, 14:07:40 »
bad connection in connector near n/s/f foglamp was the cause of my problem--Roger
