Author Topic: Fuse keeps blowing but need help!  (Read 1946 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 06 February 2010, 11:02:51 »
Fuse number 27 under the bonnet keeps blowing it's next to a relay but I don't know what for!can you help it has a 30amp fuse in I've not got a car manual to check if that's right or not.is a 2.5td bm engine.thanks all
scream if you want to go faster!!!
Re: Fuse keeps blowing but need help!
« Reply #1 on: 06 February 2010, 11:10:25 »
This ...... clicky shows the layout, but doesn't show fuse 27  :-/  :-/
  • Auckland
    • Mazda MPV
« Reply #2 on: 06 February 2010, 11:17:08 »
There was a thread on here a few months ago about a mysterious fuse problem. I think that turned out to be caused by the intercooler fan seizing up.
I cannot remember which fuse it was and I don't have a diesel so I can't check if there actually is a seperate intercooler fan so apologies if that isn't the cause.............
mr ICE man
  • dolgellau wales
« Reply #3 on: 06 February 2010, 11:31:02 »
Is definatly fuse 27a and on that diagram but still don't know what it is!everything seems to work ok but could be missing something all fans are working well from what I can see!
PC Techy
  • Bath
« Reply #4 on: 07 February 2010, 15:20:56 »
Its the intercooler fan fuse, mine kept blowing aswell. so checked fan today and it's siezed solid.
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
