Author Topic: CCR 2006 Removal  (Read 3557 times)
Snake Pliskin
CCR 2006 Removal
« on: 11 February 2010, 15:14:44 »
I have a CCR 2006 Radio/CD player fitted to my Omega. I have decided to replace Unit but am buggered if i can work out how to remove it. Any suggestions????
Re: CCR 2006 Removal
« Reply #1 on: 11 February 2010, 15:19:52 »
you need special double din removal pins, there are grub screws which need to be removed first
Snake Pliskin
« Reply #2 on: 11 February 2010, 15:21:43 »
Any ideas where i can get these? and is there a procedure laid down somewhere with instructions for removal (i dont want to break anything!!)
  • Auckland
    • Mazda MPV
« Reply #3 on: 11 February 2010, 15:30:46 »
Undo the 4 grub screws.
Insert a pair of double din radio release keys until they click in then pull.
Took me an hour to get mine out >:(
If you have an auto you have to move the gear selector back to D to get the radio out. If you lift the gear surround to release the catch make sure not to drop anything down the hole because you will never find it again.
http://www.dndservices.co.uk/pc5-110.html
« Last Edit: 11 February 2010, 15:46:09 by andyh »
Snake Pliskin
« Reply #4 on: 11 February 2010, 15:37:29 »
I take it the grub screws are the ones you need a right angle allen key or tqx drive for?
« Reply #5 on: 11 February 2010, 16:28:08 »
IIRC it`s a 3mm allen key. Don`t force the unit out once the din tools are in place. Gently ease it out otherwise you`ll rip the faceplate off
« Reply #6 on: 11 February 2010, 16:30:21 »
make sure the pins are pushed fully back as well  :y
Snake Pliskin
« Reply #7 on: 11 February 2010, 16:33:31 »
Cheers all, i'll give it a go tonight once it gets dark (just to see myself off) got to do washing up first >:(
Edd
  • South Ockendon
« Reply #8 on: 11 February 2010, 20:17:06 »
did mine recently and found it very stiff to move, took the cd cassette out and used it as a handle in the end
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 11 February 2010, 22:56:38 »
Allen Keys or Torx T8 for the grub screws.
And spend an extra 50p on the genuine Vauxhall removal keys as the Autoleads/Halfords ones are useless in the Omega due to the cage being very tight.
Radio & Decoding Technician
david_omega
« Reply #10 on: 11 February 2010, 23:58:53 »
what a shitter, i just had one of these out tonight as the cd changer got jammed, repaired it, then when re fitted it, must have nocked the connector block at the rear just slightly, as no display, another 30 mins faffing about with removal tools, got her out, refitted block into cage, job done.
why does everything have to be an arse hole the night before delivering a car for a customer, and to top that, working in -1 in the dark grrrr lol
