Author Topic: Relay U/S?  (Read 1665 times)
PhilP
Relay U/S?
« on: 13 February 2010, 19:09:43 »
I can't get the auto box out of P.  Brake Light Check relay is not working.  Anyone had this problems and no how to resolve it.  Is and Relay or something else.
Thanks
Phil
2.5 TD Omega CDX Estate 1998.
Re: Relay U/S?
« Reply #1 on: 13 February 2010, 20:02:36 »
Thanks
Phil
Brake switch above the pedal by the sound of it. If you remove the trim from around the gear selector, you'll see a yellow lever, lift it & you'll be able to move the selctor from P. Obviously your brake lights need to work, if the message isn't going, you've either a light out or neither are working due to the duff switch.  :y  :y
