Author Topic: hi how do i get to the heater fan on 2.5 cdx  (Read 2281 times)
kentguy
  • kent
  • hi
« on: 15 February 2010, 18:51:11 »
hi can anyone tell me how to get at the heater fan  its on a p plate ty
Re: hi how do i get to the heater fan on 2.5 cdx
« Reply #1 on: 15 February 2010, 19:03:38 »
Trunking that holds blower motor is attached to pass. side inner bulkhead behind glovebox, so it`s glovebox out, three screws to remove blower motor, bloody awkward but doable
« Reply #2 on: 16 February 2010, 13:03:09 »
As above glovebox out.  You will need to remove plastic tray that holds all the electrical cables (cut off all the insulating tape firtst) in order to get the blower unit out.  I seem to remember 4 screws with the top 2 being really awkward to get out (and put back)  When I replaced the plastic tray I tie wrapped the cabling to it!!  Good luck.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 16 February 2010, 14:49:01 »
I think that Kent Guy may have to replace the trunking that holds the resister pack ( Hedgehog)  Is this doable at the same time as the motor or is there more dismanteling to do. Hope this helps Vince
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 16 February 2010, 14:51:26 »
Following My last post on this subject would a faulty resister pack cause discharge of the battery even when the blower is switched off.
« Reply #5 on: 16 February 2010, 15:50:42 »
Most common cause of this is a failed/failing power sounder battery...
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 16 February 2010, 16:36:10 »
The problem with the battery drain is cured with the blower motor fuse removed so assumed it might be the resister pack.
« Reply #7 on: 16 February 2010, 16:37:57 »
What makes you suspect the resistor. Could it not be the actual blower motor :question
  • Auckland
    • Mazda MPV
« Reply #8 on: 16 February 2010, 16:40:07 »
Have you got a speed selector switch (and straight forward resistors) or climate control and an electronic speed controller?
I'm thinking that with resistors that off means off but with the electronic gubbins a fault could draw power when the car was unattended.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #9 on: 16 February 2010, 17:24:33 »
It has climate control.I fitted a new Hedgehog because blower would not stop even with ignition off. The blower had made a minor noise now and again before I changed the Hedgehog .With new Hedgehog ran OK for a while then blower started making a lot of noise.and battery drained even with ignition off, only way to cure drain was remove blower fuse.Not sure now where to look.
« Reply #10 on: 16 February 2010, 17:46:51 »
Sounds like the blower motor
