Author Topic: Rear door and fuel filler locking problem  (Read 2471 times)
Omega M3
    • Omega 03 3.2
« on: 17 February 2010, 18:45:36 »
Hey guys,
Today i noticed that only my right rear door central lock doesn't work either from remote or key
only you can open or close it manually
i checked fuse no 13 and 19 they are OK
so what to check else ?
« Last Edit: 18 February 2010, 18:02:04 by omegaM3 »
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: Rear door locking problem
« Reply #1 on: 17 February 2010, 18:50:30 »
first check the door wire from post B to the door there is a wire with a screw plug  make sure it ok, if ok then the servo may have gone in the lock. :y
Omega M3
    • Omega 03 3.2
« Reply #2 on: 18 February 2010, 15:32:34 »
Thanks for reply
i found that fuel tank lock also don't work
so what's the problem ?
« Reply #3 on: 18 February 2010, 15:57:41 »
Thanks for reply
Door solenoid tired. As for the fuel flap, again, tired solenoid. Fuel flap could have been gone a while, one of those things you just assume is locked :question Got both solenoids here from facelift if you need `em :y
Omega M3
    • Omega 03 3.2
« Reply #4 on: 18 February 2010, 16:27:51 »
Thanks for reply
But i think it's an electric issue both have the same problem at the same time
