Author Topic: Siemens NCDC 2015 problem  (Read 3859 times)
Stian22i
« on: 17 February 2010, 09:56:42 »
Hi. I have a Omega 2.5dti facelift with a siemens 2015 installed. But i have trouble with the cd and navigation slot. It won't read any cd's. Not even the original navigation cd.
Anything i do with this?
I have a original CD 70 Navi, can i use somthing from that to fix the 2015. Or is there a way to use the CD70 i my omega?
Greetings from Norway.
Stian
Re: Siemens NCDC 2015 problem
« Reply #1 on: 17 February 2010, 10:16:30 »
have you been using CD-R's in both the changer and single disc lot? These tend to nacker the lasers. You need to get it repaired, DaveDND a member here does repairs, not sure what postage would be though from Norway  :-/
Stian22i
« Reply #2 on: 17 February 2010, 10:19:56 »
Yes i have. Possible to switch to the laser from the CD70?
« Reply #3 on: 17 February 2010, 10:22:17 »
Don't know, one of the electronic wizards will be along shortly  :)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 17 February 2010, 14:00:15 »
Not sure on that one - gut feeling is probably not.
Radio & Decoding Technician
www.dndservices.co.uk
Stian22i
« Reply #5 on: 17 February 2010, 14:28:49 »
Ok. Do you know where to get a new laser? Is it a difficult job to change?
So the CD 70 is useless to an omega? It's a different wirering system than the 2015 isn't it?
« Reply #6 on: 17 February 2010, 19:00:58 »
CDRs knacker the laser.  Parts are virtually impossible to get now.
CD70 uses different laser. CD70 cannot be fitted to Omega (believe me, I've tried)
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
    • Grischke Solutions
« Reply #7 on: 17 February 2010, 23:33:51 »
B4 you do anything, try to take it out and clean the laser. It's been several years now, and lenses needs cleaning sometimes. I reckon it should be fine.
Stian22i
« Reply #8 on: 18 February 2010, 08:50:02 »
Yes, should try that. Tried to get a cleaning cd in but with no success :P
bigmac
  • Devon
« Reply #9 on: 18 February 2010, 17:41:14 »
Pm me mate if you can fit it into a vectra b i'm sure you can in an omega ;)
