Author Topic: Cooling fans  (Read 2868 times)
Omegadoha, Desert Member
  • Doha, Qatar
Cooling fans
« on: 21 February 2010, 16:01:03 »
There are two fans at the front of the engine and one at the back. Is the back one for the condenser? And when does it kick in?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Cooling fans
« Reply #1 on: 21 February 2010, 17:57:50 »
me finks front two air-con back one cooling
Hoof'land storeman.
Debs.
Re: Cooling fans
« Reply #2 on: 21 February 2010, 20:05:40 »
The rear fan is the 'main' the front two 'auxiliary' fans are also the air-con fans: the auxiliaries will work independently of the air-con and will begin to run at half-speed before the coolant temperature rises high enough for the main fan to also be required.
All three fans (should) have a half-speed and a full speed function for engine cooling. :y
