Author Topic: Sidelight Bulb Issue  (Read 3021 times)
pedroMV6
  • York
  • Der Metzgermeister
« on: 28 February 2010, 19:19:22 »
The MV6 keeps blowing the front left sidelight bulb. Seem OK for a couple of days then pop.
Right front and rears all OK, interiors all OK.
Any bright ideas, please? :D
mudflap
  • NW London UK
  • My Green Goddess
Re: Sidelight Bulb Issue
« Reply #1 on: 28 February 2010, 19:38:50 »
In any other application would say faulty power issue like a power surge caused by faulty regulator, only thing i can think of is - are the bulb pins fitted tight enough in the bulb socket? a sharp shock or rattle could break the "mantle" (for use of a better word) inside the bulb. :-/
« Last Edit: 28 February 2010, 19:39:21 by mudflap »
If it's got tits or wheels  it's bound to give you trouble
mantahatch
« Reply #2 on: 28 February 2010, 19:44:25 »
Yes I would agree with what mudflap wrote. I would add vibration is a major killer of lamps (bulbs) I suffer particularly badly on my motorbike.
Is your headlight reflector loose/broken and rattling around as you drive.
HTH
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #3 on: 28 February 2010, 19:49:20 »
also a bad fuse holder can doit as well, if it not crimping the fuse.
pedroMV6
  • York
« Reply #4 on: 01 March 2010, 19:58:29 »
Seems the reflector is in need of attention, as it is indeed loose and rattling around a bit..
Probably need some new adjusters. :y
