in car phone
Started by dave10, 01 February 2010, 23:12:41
dragonlord
no ones mentioned it
but tesco sims work as they use voda
seem to workout the cheapest of the lot
Quoteno ones mentioned it
Tesco uses o2  :y
Virgin in T-Mobile  :y
QuoteTesco uses o2  :y
GSM900 so should work :y
QuoteVirgin in T-Mobile  :y
GSM1800 so definitely won't work :(
dave10
well called 02 it is a new sim that is in it ive topped it up £10 and still no network even if i try to search for a network manualy or auto still get (no network available) message
robbo2345
 :-[ :-[ might be having a senior moment here but can you only use payg sims or can you use a contract sim ? I am on 3 network would that work?
life is too short ...... so live it every day !!
Dave DND
Quote:-[ :-[ might be having a senior moment here but can you only use payg sims or can you use a contract sim ? I am on 3 network would that work?
3 will definately NOT work
Radio & Decoding Technician
www.dndservices.co.uk
Quotewell called 02 it is a new sim that is in it ive topped it up £10 and still no network even if i try to search for a network manualy or auto still get (no network available) message
Is it a saloon, and do you have aerial on roof.
Contract / PAYG both will work, as long as PAYG has enough credit  :)
3 Network will not work, its only o2 & Vodafone, and any virtual operator that uses them (Virgin/Tesco)
biggriffin
#24
as every one has said.
  O2 OR VODAPONE.
as for the areial the two that gm fitted were one that worked the sat nav as well has two cable connectors and a red/white plug for the ariel amp.
   the second is a stubby which is purelly for the phone.
  and not being smug got both on roof of mine.
Hoof'land storeman.
dave10
yes saloon and arial on the roof yeserday i was taking a close look athe radio and noticed 2 scuffs on the sides im thinking the radio has been removed in the past and the arial not put back in but i cant remove the adio i dont have any radio removal tools is there anything else i can use
Quoteyes saloon and arial on the roof yeserday i was taking a close look athe radio and noticed 2 scuffs on the sides im thinking the radio has been removed in the past and the arial not put back in but i cant remove the adio i dont have any radio removal tools is there anything else i can use
4 small nails. But easier with keys.
The areial socket at back should be clipped in cage.
Check aerial is connected in drivers kickpanel
dandy
I have exactly the same problem. Have tried with Orange and O2. Same problem, SIM is read, phone book is loaded etc. but no signal. I did actually make a call once but was literally under a mast. So it seems that the aerial isn't doing its job. Two cables in the boot are "one star" so I'm told, nothing to do with phone.
System is a Phillips CRT700, Car 1999 Omega CDX, car was one year old when I bought it. I did try a Vauxhall garage (Brandish In Coventry) many years ago but the Diagnostic Terminal said everything was OK and in reality they hadn't a clue.
So, everything seems to work, SIM is read, data loaded, searches for Network, can't find a network. Ideas?
dave10
the ariel had came out of the back of the radio on mine mate and is working fine now
Mr Hagon
Any 02 or Vodafone SIM will do.  In my case I have an 02 PAYG SIM that works fine in that it shows up as BT CELLNET.  I don't intend ever making any calls and as such haven't topped up the SIM.  Should it ever be disconnected I will just ask 02 to send me another freebie and do the same again.
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
