Author Topic: TOWBAR ELECTRICS  (Read 4808 times)
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
TOWBAR ELECTRICS
« on: 01 March 2010, 19:15:22 »
Anyone know if there's a Vx loom/plug available to connect into when wiring the 12N socket from the towbar?
Or is it a case of using Scothlok-type connectors behind the N/S/R light unit?
Oh, it's my '99 mini-facelift estate that this concerns.
TIA.
Re: TOWBAR ELECTRICS
« Reply #1 on: 01 March 2010, 19:17:12 »
There's a plug behind the plastic rear face in a saloon boot .. but no idea about an estate .. :(
« Reply #2 on: 01 March 2010, 19:18:55 »
If you have a box of Scotchlocks ..... bin them! Solder your connetions.  :y
Welung666
« Reply #3 on: 01 March 2010, 20:45:35 »
Estate Vx plug is in the rear of the spare tyre well, left hand side :y
Hannah Judes Dad
    • the misses round the bend
« Reply #4 on: 01 March 2010, 21:16:32 »
Near or behind the jack
alfie
  • Gwent
    • Mondeo Ghia estate tdci
« Reply #5 on: 01 March 2010, 21:17:30 »
Vauxhall plug in system was priced at about £99+vat about 3 years ago,so god only knows what they cost now.
Alfie.
« Reply #6 on: 02 March 2010, 10:24:48 »
Alfie.
Fairly sure its been discontinued, wanted one for my saloon.
« Reply #7 on: 02 March 2010, 10:34:06 »
Alfie.
Still available from Germany I believe .... at a price !!!
« Last Edit: 02 March 2010, 10:34:21 by entwood »
« Reply #8 on: 02 March 2010, 10:36:15 »
Alfie.
You haven't got the loom that uses the original socket in the boot though, it's like mine & plugs onto the loom around the tail lights.  :y
« Reply #9 on: 02 March 2010, 10:36:42 »
Just solder the connections :y :y
Sixstring
  • Lydney, Gloucestershire
« Reply #10 on: 08 March 2010, 13:41:23 »
This little plug in the spare wheel well of the estate.........Can you just trace which wire goes to indicators, brake, and sidelight on that plug, and just solder the 7 core wires on to it???
would make fitting an awful lot tidier for me when I fit one!
« Reply #11 on: 08 March 2010, 13:51:39 »
Car ................. lamp ............12n
Black/blue ....... rear fog .......blue
black/white.......left turn .......yellow
black/green .....right turn ......green
grey/lack ........left tail .........black
grey/red .........right tail .......brown
black/yellow ....stop lamp ....red
brown ............earth ..........white
be aware though, that the brake light is wired via a relay base behind the glove box on facelift cars/above the driver's feet prefacelift cars, for the 'trailer check control' So you either take the feed directly from the stop lamp or bridge the terminals of the base or buy the check relay which will extend your brake light check to your trailer when connected to your car. IIRC £16 from the dealer ... the part number is on the site if you look hard enough  :y
Sixstring
« Reply #12 on: 08 March 2010, 14:59:00 »
Thanks Andy,
I owe you one!
Mike.
« Reply #13 on: 08 March 2010, 16:24:14 »
Thanks Andy,
I owe you one!
Mike.
Found it - Trailer check control..... 90463123  :y  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1175364013/all
splott
  • Bebington, The Wirral
  • Veccy with a Miggy engine..............
    • Vectra GSI 3.2 v6
« Reply #14 on: 08 March 2010, 17:18:53 »
You will have to get a solid state relay to fool the lamp check. Readly available at the towbar suppliers.
Had one fitted last year, no prob at all. Not expensive either. :y
Thank you for reading this. I’ve officially wasted your time!
