Author Topic: Auxillary Water Pump  (Read 1983 times)
SnakePliskin
  • Anglesey
  • OMEGA MV6 Estate Manual Owner
« on: 12 March 2010, 10:27:52 »
Hiya all
I think my auxillary water pump is at fault for my heating issues as when i bypassed it the heating was luke warm. Im putting that down to the water passing through the matrix to quick due to no flow control.
NOW
When i had the pump out i wired her up to a supply and SURPRISE SURPRISE the pump doesnt work.
Would this be the issue if im right in thinking?
Love VX's always Have
Re: Auxillary Water Pump
« Reply #1 on: 12 March 2010, 10:50:20 »
In my experience the pump makes no difference to the heating. It only allows "residual heat" from the engine to be used when the car is parked.
I removed mine entirely when I went to LPG and noticed no difference in heater performance.
Also, you can't have too much flow through a heater matrix. I would suggest, if performance of the heater is poor, that you have either a partially blocked heater matrix or the heater bypass valve is defective.
Worth getting some cooling system flush, running that through the cooling system and then refilling with a correct antifreeze mixture if it hasn't been done recently. Consider popping off the heater matrix connections at the bulkhead and reverse flushing it with a garden hose too. :y
SnakePliskin
  • Anglesey
« Reply #2 on: 12 March 2010, 10:53:18 »
Heater bypass valve?
Any pics on a location or a way of testing?
« Reply #3 on: 12 March 2010, 12:02:33 »
Behind passenger bank of cylinders.
pull the vac pipe off it, see if that improves heater - seen a couple now where the vac is always present!
