Author Topic: thanks to TheBoy again...  (Read 3416 times)
Re: thanks to TheBoy again...
« Reply #15 on: 17 February 2008, 20:16:43 »
The V6 looked like a parked Steam train today  :(
That bad??   :-/
Not really, only noticable with the bonnet up. Drivers side only up the top, not helped by the cold day today!
About as much as few lit ciggys as guess.
« Reply #16 on: 17 February 2008, 20:17:41 »
It stands me at a tenner but, is a known good un.....
Done  :y
Nowhere near as bad as my MV6 did after I stretched its legs a bit  :'(
Think yours was running a bit rich, strong smell of fuel burnt fuel when i was following you!
Was cold, so on full choke :y
Full throttle too  ;D
« Reply #17 on: 17 February 2008, 20:19:01 »
Done  :y
Never anywhere near full throttle until up to temp - I car for that engine :y.  I just don't slow down for corners ::)
« Reply #18 on: 17 February 2008, 20:20:18 »
Done  :y
I have to in the Estate, its very tail happy!
Taxi_Driver
« Reply #19 on: 17 February 2008, 20:38:59 »
I will gladly bring a V6 radiator......I need the space!
Dont spose you have a 2.2 rad in your collection do you?
Im not 100% it is the rad.......carnt see where its leaking at the mo.......but im loathe to pay vx dealer £190 for a new one.
« Reply #20 on: 17 February 2008, 20:46:01 »
Done  :y
And budget tyres...
Though I would say I reckon your estate corners better than the 2.2 with plastic tyres
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #21 on: 18 February 2008, 11:43:01 »
I had the handbrake "adjusted" for it's last MOT....  it was fubarred again inside 6 months....       I'm beginning to think the garage that did it isn't terribly au fait with Vauxhalls.....
the Radiator weep is definitely a new "issue" , from your description of it being around mounts, i guess it might be from being sat on.....   stood on, leant on, and generally abused , during the last few weeks of my ownership, much like the front grille, which was, prior to that, spotless, and only 18 months old, having been replaced after a deer incident....  ....   i would definitely have noticed the Rad weeping.... .... having  spent so long looking for leaks weeps, and steamy spots....  with engine running and bonnet open....
I paid for the breathers to be cleaned with it's last service..   from your description, either I got ripped off, or the HG being shagged affects a lot more other things than I thought about....
Max
MaxV6
  • Oxford UK
« Reply #22 on: 18 February 2008, 11:45:05 »
as Estates go, it handled rather well I thought....  ;)  new one isn't quite as stable, despite being on expensive rubber.....  but I suspect new rear shocks might resolve that....
« Reply #23 on: 18 February 2008, 12:24:30 »
Max
There was a lot of old crud in there, especially in the front section of the breathers, very brown, very yuKK!!
Just goes to show, if you want a job doing right, do it yourself, then you know its done!
