Author Topic: Tow Bar Electrics  (Read 3578 times)
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
Tow Bar Electrics
« on: 16 March 2010, 15:24:27 »
Hi
Following on from my previous thread, I'm looking at removing the tow bar and electrics. I removed the boot trim and I've find the following wiring
http://i768.photobucket.com/albums/xx323/humpy76/Autoleads/T-Bar.jpg
Now I'm not sure of the best course of action:
Should I just snip each wire by the scotch lock and tape up or should I remove each scotch lock and reconnect each original wire back together.
All advice greatly appreciated.
Cheers
mantahatch
Re: Tow Bar Electrics
« Reply #1 on: 16 March 2010, 15:50:31 »
I personally would remove the entire scotch loks.
Are you selling your tow bar ?  :y I may be interested if you are.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 16 March 2010, 16:06:13 »
I would remove all scotchlocks, resolder original wires back together, sleeving them with heatshrink and then tape up the outside of the loom to restore it back to how it should have been.
Thats also quite a nice picture of how not to do it - would you have any objections to me using that picture on my website ?  Obviously no reference to your good self !!
Radio & Decoding Technician
www.dndservices.co.uk
  • Auckland
    • Mazda MPV
« Reply #3 on: 16 March 2010, 16:25:03 »
The Scotchblocks are IDC (insulation displacement connectors) and shouldn't have broken the original conductors. If you prise open the plastic clip you should be able to pull the metal comb out without breaking the cables.
My preference is for Hellerman sleeving or heat shrink sleeving but you can't slide the sleeve over a continuous cable (hence the need to cut and solder)  :(
Taping over the nicks in the insulation on each cable should be safe enough. I would be inlined to carefully wrap each wire with electricians tape then finish by neatly binding it all with electricians tape.
« Last Edit: 16 March 2010, 16:26:33 by andyh »
« Reply #4 on: 16 March 2010, 16:26:38 »
Thats also quite a nice picture of how not to do it - would you have any objections to me using that picture on my website ?   ....
You could title it .....
Lazy arse towbar fitter!  ::)  ::)
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #5 on: 16 March 2010, 16:58:41 »
 ;D  ;D  ;D
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #6 on: 16 March 2010, 18:33:32 »
Hi Dave DND
No problem with you using the photo do you need me to e-mail it to you!
Plus am I right in thinking that the professional way of installing would of been to use the female black connector???
« Last Edit: 16 March 2010, 18:41:08 by cdgriffin »
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #7 on: 16 March 2010, 20:05:10 »
ROFL.
Nice job!
Unfortunately the Vauxhall plug costs an arm and a leg. I think most people solder into the existing wires ... I did.
Work is the curse of the drinking classes (Oscar Wilde)
Grrrrrr
  • Buckinghamshire
« Reply #8 on: 16 March 2010, 20:05:52 »
Why do you want to remove it? You never know when it might come in useful.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 16 March 2010, 22:39:47 »
Hi Dave DND
Thanks ! - No need for email, I`ve got the picture.
Yes, I would have used the black connector, but maybe saved a few quid by using one of the far cheaper patterned ones instead of the genuine one.
griffin
  • West, Wiltshire
  • a
    • 2.6 CD
« Reply #10 on: 17 March 2010, 07:51:53 »
Hi Grrrrr
Someone decided to hit the back of the car and have shattered the plastic connector so its safer to remove I think.
Martin_1962
« Reply #11 on: 17 March 2010, 21:11:29 »
Hi Grrrrr
They are pretty cheap anyway. About £7 to £9 for a 12S
