Author Topic: IR Remotes still available / re-programming etc  (Read 7347 times)
ScaniaV8
  • Luton, Bedfordshire
« on: 13 March 2010, 15:34:39 »
Currently driving an early 1995 Omega CDX - existing seperate remote IR device is knackered.  Can these still be obtained from VX Dealer and how can they be re-programmed?
Thanks
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: IR Remotes still available / re-programming etc
« Reply #1 on: 13 March 2010, 15:42:12 »
have you got your car pass code??
ScaniaV8
« Reply #2 on: 13 March 2010, 17:58:24 »
unfortunately I do not have the Car Pass code.
Humpy
  • Tunbridge Wells, Kent
« Reply #3 on: 13 March 2010, 18:09:47 »
I'm not the expert but both mine and the other half's cars have these. I got a new old stock one of Ebay but apparently they have to be programmed by someone with a Tech 1 not Tech2 'cos Tech 2 won't do it. I'm sure one of the other guys will confirm or elaborate on this but that's how I understand it. My existing remote won't work unless you more or less wave it in the drivers door window whereas the wife's remote works from about 10 feet away!!
Humpy
Grrrrrr
  • Buckinghamshire
    • Jaguar. WTF have I done?
« Reply #4 on: 13 March 2010, 22:30:53 »
There are 2 types of security fitted. 1 just an immobiliser; 1 immobiliser and alarm. The former has no code the latter needs a code. A main dealer can send away for it but they will charge.
From memory a new IR key can be bought for £40 - £60 from a dealer. It can be programmed using a tech 2. You just plug it in and then point it at the roof as if you were resynching.
Cannot remember who did mine. Aylesbury autolocks? Remember a lot of people talked a lot of rubbish until I found the guy and in the end he was here about 3 minutes coding the key.
Work is the curse of the drinking classes (Oscar Wilde)
Grrrrrr
  • Buckinghamshire
« Reply #5 on: 13 March 2010, 22:32:40 »
Humpy
Stupid question but have you replaced the batteries?!
Humpy
« Reply #6 on: 14 March 2010, 07:33:50 »
Yup :(
Humpy
« Reply #7 on: 14 March 2010, 09:13:00 »
For all IR cars, Tech2 will *NOT* be able to program keys.
Would have to check, but would have thought all IRs would need a code, regardless of alarm or not  :-/.  Not got a Tech1 to play with though.
Tech2 can do all non-IR cars, all of which need a code regardless of alarm or not.
Welung666
« Reply #8 on: 14 March 2010, 17:19:36 »
Does the "My Naff Code Reader" cover the IR or does it no go back far enough? If not have fun trying to find ALDL software! :o
« Reply #9 on: 14 March 2010, 19:19:50 »
I really wouldn't trust that to do any programming - seen the results of "My Naff Code Reader"s attempts to program fobs to alarms, and pair radios to displays.  Mind you, I'm getting a better-than-50% success rate at recovering from "My Naff Code Reader"'s corruptions...
Welung666
« Reply #10 on: 14 March 2010, 19:21:32 »
I can pick a tech1 up fairly cheaply it's the software that I'm finding very hard to find
« Reply #11 on: 14 March 2010, 19:22:47 »
Omega has a specific cartridge iirc.
Omegatoy
  • UK
« Reply #12 on: 14 March 2010, 20:10:36 »
correct!!!! would offer to do any oof members cars with mine should they need it,trouble is they have to drive to spain!!!! :y
Abiton
« Reply #13 on: 14 March 2010, 21:02:49 »
If you're a bit cunning you can actually transplant the chip that holds the code from a non-working/poorly working IR remote into A.N. Other.
See here: http://www.omegaowners.com/forum/YaBB.pl?num=1255721218
Happy to have a go at this for any members with this problem, no gaurantees obviously, as parts could be damaged during the transplant surgery.
Welung666
« Reply #14 on: 14 March 2010, 21:41:46 »
Can you not get an extension cable? ;D ;D ;D
Page created in 0.022 seconds with 20 queries.
