Author Topic: X30 Connector  (Read 2139 times)
ajax
  • Northampton
X30 Connector
« on: 19 March 2010, 15:28:06 »
Would anyone be able to tell me where the connector labelled as X30 on the circuit diagram actually exists on the car please?
Due to the engine mods I've made I need to hot wire the A/C and the location of this plug is crucial to that.
Connector marked in red!
TIA
« Last Edit: 19 March 2010, 17:26:55 by ajax »
Drives: Omega CDX 2.3 diesel auto Hybrid, Opel Monza 24v Manual
Dany
  • Belgium
Re: X30 Connector
« Reply #1 on: 19 March 2010, 18:17:25 »
Don't know if it helps but TIS said the 9 pins X30 connector is in the fuse box, next the ECU.
ajax
  • Northampton
Re: X30 Connector
« Reply #2 on: 19 March 2010, 18:51:11 »
Well it sort of makes sense but doesn't help really! ;D ::) Mainly because the ECU is no longer there. I looked here http://www.omegaowners.com/forum/YaBB.pl?num=1176542235
but it still doesn't make sense. I don't even understand what the difference is between an A/C coolant pump relay and an A/C compressor relay. Surely the compressor is the pump?! :-/
I wonder if it's referring to the plug marked 16 - Carrier plug in the diagram?
« Last Edit: 19 March 2010, 18:54:31 by ajax »
Dany
  • Belgium
Re: X30 Connector
« Reply #3 on: 19 March 2010, 19:36:09 »
So, I'm sorry but I can't help you for this...  :(
ajax
  • Northampton
Re: X30 Connector
« Reply #4 on: 19 March 2010, 19:38:18 »
I'm grateful anyway, it's given me something to check out tomorrow! 8-) :y
