Author Topic: major ecu prob  (Read 2542 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
major ecu prob
« on: 19 March 2010, 18:00:30 »
recieved my chip today off terry and fitted via socket into unit end428 if that helps plugged it in to car and it starts but revs alot on tickover and rev counters not working!chip is correct way around and all joints seem ok have checked many times!!
i cant put the old chip back as it was damaged upon removal!
so can anyone help?
can i get another ecu if its damaged???
scream if you want to go faster!!!
Re: major ecu prob
« Reply #1 on: 19 March 2010, 22:32:18 »
If you change ECU, need to change immobiliser ECU and key transponders.
Re: major ecu prob
« Reply #2 on: 19 March 2010, 22:40:48 »
If someone has the correct standard chip I could probaby burn a copy of it. Might get you back up and running?
Or send me the remains of the old one and I might be able to copy that assuming all the pins are there in some form or another.
mr ICE man
  • dolgellau wales
Re: major ecu prob
« Reply #3 on: 20 March 2010, 09:31:17 »
is it possible to piggyback the ecu with mine so the car is drivable?im stuck without and was going away today!!
Re: major ecu prob
« Reply #4 on: 20 March 2010, 10:01:55 »
No. ECU needs to be there and paired with immobiliser and transponders. :(
mr ICE man
  • dolgellau wales
Re: major ecu prob
« Reply #5 on: 20 March 2010, 10:44:40 »
So how much is it to get a new ecu paired?I don't see how it's the chip I think the ecu is nacked!!
  • Auckland
    • Mazda MPV
Re: major ecu prob
« Reply #6 on: 20 March 2010, 13:09:14 »
Have you checked for fault codes?
Is it possible that something wasn't reconnected properly when you plugged the ECU back in to the car?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: major ecu prob
« Reply #7 on: 20 March 2010, 13:14:14 »
What damage did you do to the chip on removal? May give some clues as to what may be wrong.
Did you damage any of the through plating on the circuit board? If so, make sure socket is soldered on both sides of the pcb - just a thought?
Radio & Decoding Technician
www.dndservices.co.uk
mr ICE man
  • dolgellau wales
Re: major ecu prob
« Reply #8 on: 20 March 2010, 13:27:23 »
doesnt appear to have any fault codes and solder is all the way through to give good connections.chip arms have snapped off,not all of them 4 in total.i repair hifis as a hobby and so know how to do nits like this usually but this has me baffled!!im leaning towards it being the chip as regardless of what i do to the board the fualt is allways the same.
unlucky alf
  • worksop, notts
Re: major ecu prob
« Reply #9 on: 20 March 2010, 16:51:03 »
so can anyone help?
i had the exact same symptoms when i done one for somebody a while ago, it turned out to be a dry joint on the socket base i put in, but once i went through them again it was worked fine.
mr ICE man
  • dolgellau wales
Re: major ecu prob
« Reply #10 on: 20 March 2010, 17:39:31 »
If it was the same problem can you tell me which joint!I've done them all five times ensuring solder is all the way through and it's still the same!
unlucky alf
  • worksop, notts
Re: major ecu prob
« Reply #11 on: 20 March 2010, 17:51:12 »
oh blimey i cant remember to be honest as it was about a year ago :-/, i just went along with a magnifying glass & re-done any that looked a little suspect, the large contact in the corner was one of them im sure, but cant remember any of the others, but a mag glass certainly helps,,,good luck :y
