Author Topic: need audio advice for S-plate MV6  (Read 3860 times)
2woody
  • Northumberland
« on: 22 March 2010, 11:04:36 »
OK, so this ex-plod I've bought has come with no stereo. I want to add one, but don't know what to ask for.
Recommendations please :-
It must have been fitted to a Vauxhall as original fitment
It must fit in the standard hole
it must plug into the standard loom with the "3-deck" connector
It must have a cd player
It must NOT have sat-nav or telephone functionality
I'm sure someone around here will be able to post that what I want is a "CDR2002" or something like that ?
Hannah Judes Dad
    • the misses round the bend
Re: need audio advice for S-plate MV6
« Reply #1 on: 22 March 2010, 18:51:19 »
The CDR 500 will fit the bill and is readily available from breakers,egay or one of the members on here.It has a single cd player and a radio.It was standard fit on several Vauxhalls including the Astra,Vectra and Omega.I hope that helps. I've got one knocking around somewhere if you are desperate and it has got it's code. :y
2woody
  • Northumberland
« Reply #2 on: 23 March 2010, 08:36:09 »
pm on its way !
Hannah Judes Dad
« Reply #3 on: 23 March 2010, 09:12:11 »
pm sent  :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #4 on: 24 March 2010, 17:37:17 »
am guessing its a facelift plod car if so the display normally dosnt work when you refit a gm unit so you may have to go std din and buy the double din converter and use a aftermarket unit.
Hoof'land storeman.
Hannah Judes Dad
« Reply #5 on: 24 March 2010, 17:40:36 »
S reg is mini-facelift iirc
biggriffin
« Reply #6 on: 24 March 2010, 17:47:56 »
oke dokey.  just put a std din aftermarket unit in. unless you are wanting to put a gm unit in. it should still have the audio plug behind the centre consle with the poss that the two power wires have been cut to power other plod gear.
Hoof'land storeman.
2woody
  • Northumberland
« Reply #7 on: 24 March 2010, 20:52:34 »
it must be a GM unit - anything else just looks chavvy to me.
mind you,I'm not fussed about it talking to the display.
methinks I'm sorted now anyway.
thanks to all  :y
I_want_an_Omega
« Reply #8 on: 27 March 2010, 18:20:31 »
well said, how did you get it sorted?
« Reply #9 on: 28 March 2010, 11:39:51 »
The 'retail' MV6 came with ccr600 with a 6 disk cdc2 changer in boot.  Hope that helps
MV6Matt
  • London
    • No car since 2022....
« Reply #10 on: 28 March 2010, 13:22:14 »
PM'd ya
Matthew
(thanks Ian)
