Author Topic: Reversing sensor problem!!  (Read 2772 times)
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
« on: 01 April 2010, 13:04:23 »
Hi all,
After digging the car out of the snow AGAIN  >:( the alarm went off and lasted about 2 minutes whereby it stopped.(Low battery maybe?) I put the car into reverse and the reverse sensor started a continuous tone only stopping when put into another gear obviously. The sensors are clear of snow. any ideas? Thanks
I'm always last in the office in the morning but I make up for it by leaving first.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Reversing sensor problem!!
« Reply #1 on: 01 April 2010, 13:32:00 »
I know that many brands of sensors can be a little "errattic" in the seriously wet/damp/cold conditions.
Is this a problem that is only happening under certain weather conditions?
Radio & Decoding Technician
www.dndservices.co.uk
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #2 on: 01 April 2010, 13:42:46 »
mine did exactly the same thing following bad weather over christmas. cannot resolve it - all components were checked so it is down to wiring - still doing it now if I reconnect the ecu.
Obviously water in electrics somewhere - VX also could throw no light on this
Drewomega
« Reply #3 on: 01 April 2010, 13:42:45 »
Hi Dave! This is the first time it has happened. Everything has been fine up until this morning. Thanks
pscocoa
« Reply #4 on: 01 April 2010, 13:44:27 »
if it is same as mine then you will need to disconnect to stop the noise - unit is on pillar behind spare wheel on mine.
Drewomega
« Reply #5 on: 01 April 2010, 13:54:27 »
Thanks guys! will have to check it out when the weather gets better as it is a handy tool.  :y
Drewomega
« Reply #6 on: 01 April 2010, 13:58:30 »
Ah! forgot to mention my outside temp sensor went haywire last week and was playing havoc with my heating/climate control. I disconnected it and checked with a DMM, ok, I then sprayed the plug/socket with WD40 and hey presto it is working perfectly. Sounds like the same damp/water ingress problem as the reversing sensors.
Drewomega
« Reply #7 on: 03 April 2010, 14:54:26 »
Well! jumped in the car this morning and put the car into reverse. No continuous reverse sensor noise! This and other similar issues must be down to damp/water ingress of connectors etc. Sun has been shining most of the day  8-) I wish other electrical problems were this easy to fix.  :y
