Author Topic: Dash dial replacment?  (Read 1671 times)
Miggster
  • Taunton
« on: 05 April 2010, 01:32:51 »
I have a 2l 8v mig with a dash that's goes up to 140 mph but I want to replace it with a dash that goes to 160 ( it's in better codition than my current one, will I be able to do it
if so what would be involved in the upgrade,
Thanks
FOR SALE!!!! 1991 astra MK2 convertible, ONLY 34,000 genuine miles!!!!, very very good condition, Roof has no leaks nor rips, good solid engine, head gasket done @ 29,000 miles
only 3 prev owners,   £1,249
Re: Dash dial replacment?
« Reply #1 on: 05 April 2010, 02:31:13 »
Not sure on that for a few reasons
160mph is generaly for the V6 motor maybe because (obviosly) thet are capable of more than 140
Plus the V6 tacho may read diifferent on a 4 pot.
Diff ratio may affect speedo reading as may the gearbox ratio's and different tyre sizes.
Other things to consider for accuracy are the ABS sensors and mayne even other sensors that I cant think of at this time in a morning.....
Some of or even all of this may be over riden with a tech 2 session.
There might be a gauide in the maitainence guide section if it has allready been done.
Other members will be online later in the day to give you more info.
« Reply #2 on: 05 April 2010, 09:44:06 »
Got a good one here from a 2.0ltr 16V. Not sure whether it`s a straight swap though :-/
« Reply #3 on: 05 April 2010, 10:32:24 »
Depends on age, they are not all electrically compatible.  Generally, from 98 onwards they are electrically compatible (and tech2 configurable for wheel size etc), but facelifts have different markings on temp gauge.
I_want_an_Omega
« Reply #4 on: 05 April 2010, 11:18:30 »
I've got a 160 dash you could have to play with if you want. Just looking to cover the cost of the postage.
Once I put an instrument cluster from a 3.0 V6 Sintra into a 2.2 Cyl Sintra. The speedo worked ok, but the rev counter only displayed 2/3's of what it should be displaying.
HTH
Page created in 0.033 seconds with 20 queries.
