Author Topic: No radio reading on display on 2.0cd w reg  (Read 4706 times)
JC2000
  • Glossop Derbyshire
« on: 03 April 2010, 10:28:24 »
HI I have a 2.0cd w reg with i believe MID display top shows trip/check etc bottom shows time and middle shows date when radio not on and cd/radio channel when on. The problem is the middle does not show anything when radio on but when switched off the date displays. Can anyone point me in the right direction. Many thanks John
Re: No radio reading on display on 2.0cd w reg
« Reply #1 on: 03 April 2010, 11:10:57 »
What radio. Factory fit?
JC2000
« Reply #2 on: 03 April 2010, 11:16:36 »
Hi Rob, Yeah factory fitted CDR2005.
Cheers John
JC2000
« Reply #3 on: 09 April 2010, 13:28:33 »
Hi , as anyone got any ideas with this problem, Cheers John
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 09 April 2010, 13:36:36 »
There are generally two versions of Vauxhall vehicle displays, one with 8 Digits and one with 10 Digits. If you connect this stereo to the wrong display, code entry is possible, but the display will either freeze or dissappear once the code has been entered. To reprogram, Turn off the Radio, Press and Hold Presets "3" & "5" at the same time, whilst switching the radio back on, and this will toggle between the two display modes.
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #5 on: 09 April 2010, 13:42:10 »
Facelifts all have 10 digit type I believe.  AFAIK, CDR2005 only does 10 digit?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 09 April 2010, 13:47:31 »
some early VDO cdr2005 also came from Corsa with 8 digits
« Reply #7 on: 09 April 2010, 13:48:19 »
Thinking asbout it, the TIDs may be 8 digit as well.
Worth a try, nought to lose :y
« Reply #8 on: 09 April 2010, 13:48:39 »
Now get off the bloody phone!!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 09 April 2010, 15:46:41 »
 :P   ;D
« Reply #10 on: 09 April 2010, 15:50:29 »
 :P   ;D
It worked - as soon as I typed that, I got a nice ringing sound ;D
JC2000
« Reply #11 on: 09 April 2010, 22:56:03 »
Hi Everyone tried the 3 & 5 Preset thing but no joy stays the same,ie no display from the radio either with CD or radio but shows date when radio off. Is it the radio or display?
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 10 April 2010, 08:25:49 »
Could be either - is the wiring at the rear intact?
« Reply #13 on: 10 April 2010, 10:08:23 »
May be worth a trip to MDTM, see if Tech2 can pick anything up - though I suspect both the radio and the display will complain of no communication with other...
charlie
  • sunderland
« Reply #14 on: 10 April 2010, 15:27:47 »
I had a simaler problem the other week,it was sorted by pulling the radio out over night,But if i had half a brain i would have just pulled the fuse like K.wood did ;D ;D ;D ;D
