Author Topic: Rev counter not working  (Read 1819 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 11 April 2010, 08:58:28 »
I've had an intermittent fault with it not working but usually comes back on but it's just stopped altogether.anyone have a clue as to what it might be?everything else works great.not sure ifit it's part of the same problem but below 3000revs the car is very sluggish,thought I'd mention it! :y
scream if you want to go faster!!!
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Rev counter not working
« Reply #1 on: 11 April 2010, 20:27:04 »
The Dash Instrument Panel doesn't actually 'plug-in'.  It just sits against a connector and held back by two screws (1 above the steeling column and one behind the centre air vents.
Could your instrument panel be loose, causing an intermittent connection?
« Reply #2 on: 11 April 2010, 20:41:21 »
Push firmly, but without "jerking" in the centre of the clocks panel .. you might just, with luck, reseat the connection if it is loose. DON'T jerk or jar when pushing or you risk breaking the perspex screen.
Might work..might not ...but worth a try .. :)
