Author Topic: Parking sensors  (Read 2821 times)
Dany
  • Belgium
Parking sensors
« on: 14 April 2010, 17:10:12 »
Hi all
I have a problem with my parking sensors, when I engage the reverse gear, there is a long long beeeeep instead the short "bip", and nothing work...
Any ideas?
Thank you for help!
Re: Parking sensors
« Reply #1 on: 14 April 2010, 17:23:45 »
This problem has been reported before on this forum and has been related to the sensors getting soaked in water during bad weather. Previous posters have reported that the problem rectifies itself after the sensors have dried out. HTH  :y
Dany
  • Belgium
Re: Parking sensors
« Reply #2 on: 14 April 2010, 17:34:30 »
I have done a research on the forum without succes. Yes but it has not rained almost for a week here, and the sensors worked perfectly two days before... I'm lost...
puffa
  • Southampton, UK
Re: Parking sensors
« Reply #3 on: 14 April 2010, 17:47:27 »
I had this problem and found that in the spare wheel area in the boot near the n/s light cluster there a fuse holder hanging out of the loom, I found that taking the fuse out and putting it back in solved the issue.
Might be worth a look, not saying it will work !
Steve
Previously owned 2.5 v6 Reflection
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
Re: Parking sensors
« Reply #4 on: 14 April 2010, 17:52:16 »
Once dried out, unplugging and then plugging back in the main box seems to cure most problems
Not sure why though
Radio & Decoding Technician
www.dndservices.co.uk
Dany
  • Belgium
Re: Parking sensors
« Reply #5 on: 14 April 2010, 18:34:17 »
Steve
I found the Bosch calculator, disconnected and then reconnected... It looks working now lol. Thank you!!
But the sensors looks more sensitive now... I have replaced my bumper for an Irmscher one, and drilled the holes for the sensors... That's the reason perhaps...?
Sixstring
  • Lydney, Gloucestershire
Re: Parking sensors
« Reply #6 on: 16 April 2010, 11:47:58 »
Dany....
I found that a liberal spray of WD40 on the connections helps, as does putting the unit in a plastic bag!!
Dany
  • Belgium
Re: Parking sensors
« Reply #7 on: 16 April 2010, 11:59:08 »
Dany....
Really? In a plastic bag? So the next time when it happens, I'll do that ^^
